Hello,
This is a Mills Castle Front machine. I need to replace the jackpot glass. I presume I need to remove the jackpot mech to do this. What's the easiest way to get it out?
Thank you!
oldslotman wrote:Take the front casting off. When you replace the jackpot there is one lever that has to be in the correct position for the jackpot reserve to work.
