Handle pump lacking pressure
Postby TJF » Thu Mar 07, 2024 6:23 am
Hello!
The handle pump on my Castle Front is lacking pressure. I picked up a new leather washer and took it apart and replaced it, being sure to soak the new washer with oil first, but it doesn't seem to have made a difference. The bolt in the end for adjusting the valve is in place but makes no difference in things.
Are there other tips or failure points I should be checking on this?
Thanks!
TJF
Re: Handle pump lacking pressure
Postby radiorich123 » Thu Mar 07, 2024 7:32 am
The barrel may be worn or pitted. Ream out the barrel,check the pump ends for a good seal and also the adj. screw.
Postby TJF » Thu Mar 07, 2024 9:19 am
radiorich123 wrote:The barrel may be worn or pitted. Ream out the barrel,check the pump ends for a good seal and also the adj. screw.
Could this be the issue? I found a picture (below) of a pump assembly and it appears to have a spring-like washer (yellow thing) on the inside. Mine just has a regular flat washer -- as in, the leather washer is sandwiched between two 'regular' fender-style washers.
TJF
Postby jmisatu » Thu Mar 07, 2024 10:23 am
That springy like washer is a guide to maintain somewhat the edge bent over shape of the leather as it is moved in and out as the handle is pulled and released. The outer edge of the leather wraps over the profile of those strips if metal. Some of the leather pieces available have the cupping shape formed when you get it and that makes it easier to control. I would say that fluted part is definitely necessary to function properly.
jmisatu
Postby radiorich123 » Thu Mar 07, 2024 10:55 am
Yes that is your problem. Look for a car wheel cylinder piston rubber cup. Must fit loose not too tight.
