TECH - SEGA Continental Slot Machine Help needed
Re: TECH - SEGA Continental Slot Machine Help needed
Postby meSz » Tue Jun 11, 2019 7:06 pm
Thanks Rich I will look once home!
meSz
Postby meSz » Fri Jun 14, 2019 10:30 am
radiorich123 wrote:Make sure the transformer for the bulbs is 115 volts not 220 volts.
Here is the starters that go with the bulbs
Starter For use with
FS-2 F14, F15, F20 preheat fluorescent lamps
FS-4 F13, F30, F40 preheat fluorescent lamps
FS-5 F4, F6, F8 preheat fluorescent lamps
FS-12 FC12 Circline lamps when operated by preheat ballasts;
F22 T8 preheat lamps; F32
FS-20 F15, F20 preheat fluorescent lamps
OK so this machine has 4 - F8-T5 bulbs and 1 - F6-T5 so this machine should have 5 - FS-5 starters and it has everything but FS-5 in it :shock:
Let me ask this .... are the reels on these SEGA slots typically slow in spinning? There appears to be nothing hanging it up and they move freely but they spin reel (see what I did there) slow! Almost as if the machine is not giving the a good spin at the get go!
meSz
Postby meSz » Wed Jun 19, 2019 1:40 pm
bump
meSz
