Mills Castle Front 3-coin escalator & jackpot glass.
Re: Mills Castle Front 3-coin escalator & jackpot glass.
Postby Bally Bill » Tue Feb 13, 2024 5:33 pm
yes it might be a while since Marshal Feys grandson is helping out with the book orders, its important to make sure you get the 2 mechanisms hold down bolts on your 10 cent machine which helps keep the escalator aligned with the mechanism properly.
1 inch length cut down to 3/4 long
1/4 x20x 3/4 long
Mills Hold down bolt.jpg (52.53 KiB) Viewed 2635 times
Bally Bill
Postby TJF » Wed Feb 14, 2024 3:25 pm
Bally Bill wrote:yes it might be a while since Marshal Feys grandson is helping out with the book orders, its important to make sure you get the 2 mechanisms hold down bolts on your 10 cent machine which helps keep the escalator aligned with the mechanism properly.
1/4 x20x 3/4 long
Yes! I learned this. Mine did have the hold down bolts, but the base plate itself was loose. Once I tightened up the four nuts at the corners, it's been reliable.
Thanks again for your help!
TJF
