Handle Stuck
Re: Handle Stuck
Postby NathanHollister » Sat Sep 07, 2024 8:17 pm
check the pin on the back of the escalator. when the copin falls down into the back of the escalator, there is a little pin that should touch it in the place where it sits until you pull the handle. Adjust the pin so it just barely touches the coin. if its too far back the coin might not register, jamming the machine. if its too far forward, it will block the coin from getting intot he escalator.
NathanHollister
Re: Handle Stuck
Postby midohioslotmachines » Fri Sep 13, 2024 1:08 pm
Okay, now that we have all the coins unjammed and the machine plays correctly, this one may be a keeper. Does anyone know someone close that can go over the mechanism and make sure it is paying out correctly. Thanks
midohioslotmachines
Location: 1627 Nantucket Drive Mansfield Ohio 44904 419.565.5684
Re: Handle Stuck
Postby mazzeosa17 » Sat Sep 14, 2024 10:18 am
Where are you located? I'm in Cincinnati, Ohio if you need me to check out/fix/clean the machine.
Thanks, Sal Mazzeo
mazzeosa17
