Bally Bill wrote:ok did you try to add a thin washer/.015 shim in between the plate to add some clearance, also be careful buying the cover plate because the round coin entry riser may be too tall to accommodate your escalator
Bally Bill wrote:good job and glad the shim fix worked out.... creativity over expenditure always served me well!
Bally Bill wrote:Hello David, Here is suggestions below
1.make sure that the reel brake wire is adjusted correctly,
2.reel bundle shaft is seated properly in frame assembly
3.look at your timing fan and bend fins to increase/decrease speed.
4.cycle mechanism and stop timing fan midway so you can check the reels to ensure they are not dragging somewhere.
