Mills, a 1934 Castle slot machine, full restoration.
Re: Mills, a 1934 Castle slot machine, full restoration.
Postby 99623 » Wed Dec 03, 2025 9:44 pm
I have been adjusting this machine, and I think I got it running fairly well. It spits out coins, reels lock up. It's been a lot of work.
Restored a 1934 Mills Castle Slot Machine.
Wasilla Locksmith Safe And Vault
Wasilla Alaska
907-315-0525
www.wasillalocksmith.com
Postby 99623 » Wed Dec 03, 2025 9:51 pm
The first wheel spins fine.
The second spins fine.
The third will stops right after the second one.
I don't want to try and adjust anything else, I don't want to create more issues.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Dec 06, 2025 10:08 am
I have been adjusting things, and most important I replaced two parts. After replacing the two parts the machine is working excellent for a 90 year old machine.
Obviously their is wear on some of the parts, and I needed to replace them with original ones I located above.
I am super grateful for the help.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Dec 06, 2025 10:19 am
I am working on the mills locks. Since I am a locksmith, and I started in 1978 I am familiar with these locks. The problem is that people file the locks to fit a new key, which destroys the locks, and then several keys fit.
I am able to take them apart and rekey them without destroying them, it's painstaking, but it keeps it original. I also can duplicate the keys.
These are well made brass locks.
When the pins are filed down, you can't do anything with them. I need a lock that has not been filed down.
As you can see it is intense work.
Wasilla Alaska
907-315-0525
Postby jmac » Sat Dec 06, 2025 10:58 am
That is interesting, I dont think many take it that far, and just grind the lock to fit key. Can you post a picture of the machine you use to duplicate mills keys?
I recently watched a few youtube videos (yes there are several out there) on picking these mills locks, and might try it on my next situation. It looks doable, but definitely tricky for novice like me.
jmac
Postby 99623 » Sat Dec 06, 2025 11:42 am
jmac wrote:That is interesting, I dont think many take it that far, and just grind the lock to fit key. Can you post a picture of the machine you use to duplicate mills keys?
I have a"HPC TEN" machine from 1985 when I purchased it new. It will cut most if not all of the keys since its versatile, it's 100% steel from Italy. I will post a photo soon. I used it a lot on vehicles from the 1980's and above.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Dec 06, 2025 5:12 pm
Finally, I have a pair of Mills keys keyed alike. I have a lock that hasn't been touched, making rekeying easier, keeping the security integrity.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Dec 06, 2025 8:29 pm
Well, well, success at last! I was able to rekey the lock and it's 100% correct, no filing down the plugs, I needed to clean up the plug, wafers, since they were frozen.
Wasilla Alaska
907-315-0525
Postby Bally Bill » Sat Dec 06, 2025 11:45 pm
nice post and pictures on your lock restoration project, thanks for sharing but beware you might get some inquires on re-keying some locks from our members!
Bally Bill
Postby 99623 » Sun Dec 07, 2025 2:42 pm
Just started putting the machine in the case for testing. The escalator is working spot on. The reels are doing excellent, pull is good.
I noticed that I have two work on the payout getting it tuned up.
Overall, it is awesome. :blob4: :blob4: :blob4:
Wasilla Alaska
907-315-0525
PreviousNext
