Bally Golden Nugget - Repair Advice
Re: Bally Golden Nugget - Repair Advice
Postby mechanic » Wed Apr 03, 2024 7:58 pm
IT MAY BE YOU RAN OUT OF COINS AND THE HOPPER TIMED OUT. THE WHITE BUTTON IN BACK NEXT TO THE RED LIGHT IS THE RESET BUTTON. CHECK THE REAR OF THE HOPPER TO SEE IF IT HAS A TAB THAT WILL HIT THE WHITE BUTTON. IF NOT YOU MAY NEED A L- SHAPED FLAT PIECE TO PLACE UNDER THE HOPPER BEFORE PUTTING THE HOPPER BACK IN. TURN ON THE MACHINE AND PUSH THE FLAT BAR IN TILL IT PUSHES THE WHITE BUTTON IN. IF THE RED LIGHT COMES ON THEN TURN OFF THE MACHINE AND TAKE THE HOPPER BACK OUT ALONG WITH THE FLAT BAR. YOU DO NOT WANT THE BAR TO SHORT OUT ANYTHING. REPLACE THE HOPPER BACK IN AND TURN ON THE MACHINE. THERE MAY BE A SLIGHT DELAY BEFORE THE HOPPER CONTINUES COUNTING OUT THE WIN. BE SURE IT HAS ENOUGH COINS IN THE HOPPER OR IT WILL TIME OUT AGAIN AND YOU'LL HAVE TO START OVER. YIKES !!
