Mills, a 1934 Castle slot machine, full restoration.
Re: Mills, a 1934 Castle slot machine, full restoration.
Postby Bally Bill » Sun Nov 09, 2025 7:56 pm
1/4-20 x 1" long
OEM Thumb Screw.jpeg (51.86 KiB) Viewed 1523 times
Bally Bill
Postby 99623 » Mon Nov 10, 2025 8:21 am
Bally Bill wrote:1/4-20 x 1" long
I have some of these old ones, I am going to look for them. Great , thanks.
Restored a 1934 Mills Castle Slot Machine.
Wasilla Locksmith Safe And Vault
Wasilla Alaska
907-315-0525
www.wasillalocksmith.com
Postby 99623 » Mon Nov 10, 2025 1:52 pm
Reel glass.
Every day I have some work done on the Mills slot machine.
Wasilla Alaska
907-315-0525
Postby 99623 » Wed Nov 12, 2025 2:05 pm
When I tried to install the reel strips in the new reel tins I purchased they didn't fit, :-X
So, I spent the whole day on the old reels straighten them out. I separated them, and basically took a small tack hammer, small anvil to the reels. I was able to restore them, running true, using different methods.
Wasilla Alaska
907-315-0525
Postby 99623 » Thu Nov 13, 2025 12:16 pm
Working on the two levers, what a :-? .... lot of work.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Nov 15, 2025 9:40 am
I am working on the reels, they spin freely, no drag anywhere.
The kicker is not spinning them enough, I need to figure out what it is, spring maybe.
Wasilla Alaska
907-315-0525
Postby mazzeosa17 » Sat Nov 15, 2025 10:58 am
It's probably the spring. But you can also check to see if the kicker three notches are too deep from wear and tear over the years. I had that with one of my machines, and had to go to a welder friend of mine to build up/fill in those deep 3 grooves/notches in the kicker.
mazzeosa17
Postby 99623 » Sat Nov 15, 2025 12:57 pm
mazzeosa17 wrote:It's probably the spring. But you can also check to see if the kicker three notches are too deep from wear and tear over the years. I had that with one of my machines, and had to go to a welder friend of mine to build up/fill in those deep 3 grooves/notches in the kicker.
Found the operating fork wasn't adjusted,, I've got it set out exactly when it snaps.
Now the reels are spinning like a bat out of hell!
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Nov 16, 2025 3:55 pm
Working on the reels, timing, release, stop, etc. It took some time to get it working correctly, but well worth it.
I did find another book today.
Wasilla Alaska
907-315-0525
Postby 99623 » Mon Nov 17, 2025 7:26 pm
More things in the mail. Sourced a original Mills bolt for the machine.
Wasilla Alaska
907-315-0525
PreviousNext
