Mills, a 1934 Castle slot machine, full restoration.
Re: Mills, a 1934 Castle slot machine, full restoration.
Postby 99623 » Mon Nov 17, 2025 7:28 pm
Finally I got the spring installed. I didn't put in earlier since it was missing before the restoration.
Restored a 1934 Mills Castle Slot Machine.
Wasilla Locksmith Safe And Vault
Wasilla Alaska
907-315-0525
www.wasillalocksmith.com
Postby 99623 » Wed Nov 19, 2025 8:41 am
I believe the reel stop springs are weak. They are 90 years old, so I am going to order new springs. I've cleaned, checked the levers, springs, etc.
We're coming along, it just takes time to get it done.
Wasilla Alaska
907-315-0525
Postby 99623 » Wed Nov 19, 2025 3:35 pm
I installed the reel strip #3. Looks good. Everything aligned up exactly!
Wasilla Alaska
907-315-0525
Postby 99623 » Thu Nov 20, 2025 1:51 pm
Well, well, well, the strips came in finally, all of them. I caught a mistake on the strips and had them redone. They are made in England.
Wasilla Alaska
907-315-0525
Postby Bally Bill » Thu Nov 20, 2025 4:43 pm
Hi, I like the reel strips from the UK and you have made some great progress on this basket case Castle! looking forward to seeing your restoration completed
Bally Bill
Postby 99623 » Fri Nov 21, 2025 8:34 am
Bally Bill wrote:Hi, I like the reel strips from the UK and you have made some great progress on this basket case Castle! looking forward to seeing your restoration completed
Thank you, I have been trying to keep it original, however the original strips are impossible to source. I am doing the best restoration that I can with a 90ish slot machine..
David Walz
Wasilla Alaska
907-315-0525
Postby 99623 » Fri Nov 21, 2025 2:08 pm
Maybe you can give me advice on why the coins jamb in the escalator dropping into the machine. I haven't done anything but clean, replace the springs, and source missing parts.
Wasilla Alaska
907-315-0525
Postby Bally Bill » Fri Nov 21, 2025 6:31 pm
does the escalator cycle nickels outside the case? or when you have it installed it jams up? if it's happening when its installed make sure you adjust the coin detector pin and the coin magnet is clean and the escalator cover plate has enough of a gap to cycle the thickness of the coin.
Bally Bill
Postby 99623 » Fri Nov 21, 2025 9:27 pm
This will jamb, not all of the time.
The problem is the plate isn't flat I think.
This is fine.
Wasilla Alaska
907-315-0525
Postby 99623 » Fri Nov 21, 2025 9:36 pm
This one is flat.
Wasilla Alaska
907-315-0525
PreviousNext
