Mills 4 column mint vendor
While at the Chicagoland show last week, I attended a Donley auction nearby and won a Mills 4 column mint vendor. It pays and plays fine but does not dispense the mints. The arm that activates.the mint mech inside the case looks correct, but when the mechanism is in the case, I see no arm engaging with the arm for the mint vendor. See attached pictures. Also there were some extra parts in the cash box, I'm not sure if these are for the mint vendor or something else. Everything else seems to work correctly. If you have this machine can you send me a picture of the side of the mechanism that has the arms for the mint vendor.
