Mills Castle rear lock
PostPosted: Fri Aug 01, 2025 7:06 am
by ChuckF
Any guidance on how to get a key for the rear lock on my machine? Or is it easier to just replace the lock & key with a new set?
Re: Mills Castle rear lock
PostPosted: Fri Aug 01, 2025 8:22 am
by tsparts4u
Hi Chuck,
The lock that you have in your back door is not an original lock. An original lock would be Ideal to put in your door, but they are quite costly.
You can get a replacement lock that works like an original, for a lot less money, if you don't mind it not being an ORIGINAL Mills BELLOCK.
Getting a locksmith to make a key to fit your lock would probably be as costly as replacing it with a lock that is more like an original.
PostPosted: Fri Aug 01, 2025 9:53 am
by radiorich123
That is not a mills lock. I have old Mills lock and key for $95.00 each and free shipping in the USA. See the photos.
