Bally's $1 slot machine
Postby Eddieb1106 » Mon Feb 02, 2026 1:04 pm
I have an older Bally's $1. slot machine that I haven't used in 20+ years, and my grandson wanted to try it out only to find a few coins jammed in the machine and apparently corroded. We got the coins out but then after closing the machine the lights did not go on, and the machine did not work. I'm thinking maybe a fuse or something similar.
Any suggestions would be appreciated. I have the repair manual but it's too in-depth.
Eddieb1106
Re: Bally's $1 slot machine
Postby flyingfred » Mon Feb 02, 2026 3:21 pm
The fuses should be in the main cabinet behind the payout hopper after you pull the hopper out.
-Fred-
flyingfred
Postby radiorich123 » Mon Feb 02, 2026 5:31 pm
If that is a E series slot machine it has a electronic board that will need repair.
Postby shortrackskater » Sat Aug 01, 2026 8:59 am
I'm a little late to this...
But, post your question in THIS forum on Newlifegames.com - There are some members who do repairs and sell parts.
https://newlifegames.com/nlg/index.php?board=75.0
shortrackskater
