Reels won’t spin after cleaning
working on a Aristocrat Grosvenor 4 reel I have cleaned machine and put back together I’ve done this many times but this time when I pull lever the reels are not spinning, everything appears to be moving it’s as if the kicker doesn’t have the strength to push them even though it’s moving. Speaking to a poker machine services in England he said to make sure the arm that hold the reels in place is vertical I asked if he ment the stopper at the back that stops the reels from moving while you build up pressure and he said no it’s vertical . Can anyone help please
