P&M Enterprise Electronic Cross Joker slot
PostPosted: Thu Dec 26, 2019 7:06 am
by firefite
I have a machine from the 50's It is electromechanical slot. It has a controller that was behind the bar that would subtract points from the machine when you cashed out and you would pay the bartender he would add so many points on the machine. all I'm missing it that controller. does anyone have one? or the slot? I could use some info on the controller part. Right now I'm making a controller and getting some of the machine to work, but not everything. Help, Dave
Photo of front panel
Re: P&M Enterprise Electronic Cross Joker slot
PostPosted: Fri Dec 27, 2019 3:44 pm
by MONTI
It's a Buckley counter slot!
Had one come into the shop sometime ago so I did a little research on it!
I've been kicking myself ever since that I didn't draw up a wiring schematic!
But as diagnosing them on the bench is pretty straight forward I didn't,
however in your case building one from scratch may be a chore!
All I have is the photos below which may or may not help you!
Not sure where I picked up these photos, it's been a while!
PS
It'll be a little bit like putting an old "Heath" kit together in the 50's and I know I'm dating myself by saying that! LOL
PostPosted: Fri Dec 27, 2019 3:58 pm
by MONTI
Also Dick Beauschel a slot machine historian who wrote many books also wrote a small book on it,
#32 in his series calling it the Point Maker!
Photo below!
You may be able to locate one, not sure on how much detail is put into the schematic/wiring diagram!
Ciao!
PostPosted: Fri Dec 27, 2019 4:34 pm
by firefite
WoW, Thanks for the info and the great photos! I have put this one aside for sometime, now you fired up again. yes I have some of the booklet that Dick put together. Thanks for th great bust. Dave
PostPosted: Fri Dec 27, 2019 5:42 pm
by MONTI
Here also is a little history on the Buckley "Flasher" as they were called as there were no spinning reels showing to the player just the flashing lights to light up various symbols!
I had originally downloaded this pdf from the rcwatts website but apparently it is no longer there on the website for some reason!
An interesting read!
Buckley Flasher Slot Machine2.pdf
(3.72 MiB) Downloaded 348 times
PostPosted: Sat Dec 28, 2019 5:16 am
by firefite
Thanks, but when you told me it was a Buckley Pointmaker I went on the net looking, I did find that site. Thanks Very much. Dave
