lock washer ???
lock washer ???
Postby ernie » Thu Mar 04, 2021 11:38 am
Hello,
Does anyone know what this type of lock washer is called? Are they still made/used? What type of equipment is required to attach them?
Many thanks,
Ernie
Screen Shot 2021-03-04 at 1.16.33 PM.png (90.92 KiB) Viewed 4104 times
ernie
Re: lock washer ???
Postby RameGoom » Thu Mar 04, 2021 9:36 pm
That's not a lock washer. It's the end of the shaft that's been peened with a special tool. Shaft is retained onto the metal plate permanently once it's formed.
Re: lock washer ???
Postby ernie » Fri Mar 05, 2021 5:59 am
Hello GameGroom,
Many thanks,
Ernie
ernie
Axel Cap / Push Nut
Postby Will » Fri Mar 05, 2021 1:38 pm
I wonder, if you needed to remove or replace that part, if you could use the correct size Axel Cap in its place.
To me it looks like a crimped axel nut.
https://www.amazon.com/Hillman-Group-88 ... 99&sr=8-33
Just a thought.
Living the best life I can in Lake Tahoe.
Will
