Looking for handle set screw for Jennings governor
Postby Phan000 » Fri Jun 18, 2021 6:08 am
Please let me know if you have this part, or can recommend a seller.
Thanks.
Phan000
Re: Looking for handle set screw for Jennings governor
Postby Steve Neul » Fri Jun 18, 2021 12:14 pm
It's probably a common bolt size. Your local hardware store could probably fix you up. Just measure the diameter of the hole to get an idea of what you need. Then when you get one look inside the hole and see if the space between the threads looks like the set screw you bought. Just go easy screwing it in in case it doesn't match.
Steve Neul
Postby oldslotman » Fri Jun 18, 2021 8:37 pm
Need a better picture. If it is what I think it is, it will be a 1/4 X 20 X 3/4 long.
Postby jeffimac » Sat Jun 19, 2021 9:13 am
Call Al Hibler (530) 335-3775 he has a ton of Jennings parts
jeffimac
