MILL NOVELTY CO. SLOT with candy dispenser
Postby paradiseestatesales » Sun Jan 30, 2022 9:12 am
Looking for info on this estate find, serial # 238122
Not currently working, not sure if lock on back is original I do not have key.
Was told it stopped working 10 years ago
Thanks, my first slot purchase
paradiseestatesales
Re: MILL NOVELTY CO. SLOT with candy dispenser
Postby paradiseestatesales » Sun Jan 30, 2022 10:21 am
I am guessing it an Owl operator ca. 1920-30s?
paradiseestatesales
Postby 63mini » Sun Jan 30, 2022 10:58 am
Mills Pointsetta.
63mini
Postby paradiseestatesales » Sun Jan 30, 2022 2:21 pm
Thanks for clarification that gives me a lot to go on
paradiseestatesales
Postby jumpinjaxsisfun » Sun Jan 30, 2022 3:46 pm
hi is there anyway you can give me some pictures of the inside payouts. mech and shoots. i am trying to rebuild the same machine.
jumpinjaxsisfun
Postby altort » Sun Jan 30, 2022 5:23 pm
slot looks to be all original, but lock looks to be a replacement, should have carriage bolts not hex head bolts holding it in place, were are you located?
P.M. me if you need more info, I have owned many goose neck slots simple to work on.
Postby paradiseestatesales » Sun Jan 30, 2022 8:15 pm
jumpinjaxsisfun wrote:hi is there anyway you can give me some pictures of the inside payouts. mech and shoots. i am trying to rebuild the same machine.
I will be glad to when I get in there
paradiseestatesales
Postby paradiseestatesales » Sun Jan 30, 2022 8:16 pm
altort wrote:slot looks to be all original, but lock looks to be a replacement, should have carriage bolts not hex head bolts holding it in place, were are you located?
Located Gainesville Florida area
paradiseestatesales
Postby jumpinjaxsisfun » Mon Jan 31, 2022 8:00 am
THANK YOU PARADISE...
jumpinjaxsisfun
Postby wallruss001 » Mon Jan 31, 2022 8:23 am
I live in McIntosh and have experience with goosenecks. You might get lucky and back out the hex bolts some on the lock enough to get the back off. The Mobile Locksmith on Archer Rd. has re-keyed several for me.
Howard
352-871-3767
wallruss001
