Pace Comet Payout Fingers install ?
Postby bhmyers1966 » Wed May 10, 2023 1:04 pm
I recently purchased a Pace Comet. I think the horizontal payout fingers are installed incorrectly as only a few actually lined up with the payout slides.
Does anyone have a photo or information as to how they should be stacked?
I notice on 5 of them there are notches of different distance from the pivot and one without a notch.
thank you in advance.
bhmyers1966
Re: Pace Comet Payout Fingers install ?
Postby oldslotman » Thu May 11, 2023 9:54 am
The one without a notch is for the jackpot. Smallest notch is bells. biggest notch is cherries. oranges is is next and then plums. Start out with the biggest notch for the cherries in the back and work forward with smaller notches until you get to the jackpot with no notch. This is for the vertical fingers. Sorry I misunderstood which fingers you were talking about. My Bad
Postby bhmyers1966 » Thu May 11, 2023 11:04 am
oldslotman wrote:The one without a notch is for the jackpot. Smallest notch is bells. biggest notch is cherries. oranges is is next and then plums. Start out with the biggest notch for the cherries in the back and work forward with smaller notches until you get to the jackpot with no notch.
If I am installing the fingers that actuate the payout slide, going bottom to top: no notch, smallest notch working to biggest at the top, is this correct ?
bhmyers1966
Postby jmisatu » Thu May 11, 2023 11:14 am
Cherry payout on top and jackpot last on bottom of grouping.
jmisatu
Postby bhmyers1966 » Thu May 11, 2023 11:33 am
jmisatu wrote:Cherry payout on top and jackpot last on bottom of grouping.
perfect !
cherry horizonal finger has the long notch as well ?
At some time, the jackpot finger was put in to actuate the 5th down slide.
bhmyers1966
