What is out of whack with Buckley vendor?
This area is to discuss trade stimulators. A trade stimulator is defined as a machine that does NOT pay the customer something of value (coin, token, etc.) when a winning combination is hit.
Postby Bruce P » Wed Nov 18, 2026 11:16 am
My Buckley 1 cent Gum Ball vendor is not spinning the reels. (I was told this may be similar to a Mills mechanism). I believe a component was knocked/forced out of place by previous owner. Can anyone tell me what is amiss from the attached photos?
Thank you
Bruce P
Re: What is out of whack with Buckley vendor?
Postby nvmos2 » Sat Nov 21, 2026 1:31 pm
The only problem I see is this;
In your second photo, there is a lever attached to the reel axel, right next to the third reel and pointing straight back; it should have a spring on the end of it.
There's a small hole in the end of the lever for the spring, which goes from that lever up to a mounting point, either on the mechanism or casting or attached to a counter, if your machine has a counter (see my photo with counter).
Reels will not spin without that spring in place.
Buckley TS with counter
Return to Trade Stimulators
