Delux Mercury 1cent machine
This area of the forum is for arcade style machines.
This is a new area and was created on 2/7/207.
Postby Cfroadhog » Sun Dec 27, 2020 10:14 am
On the inside works is there a spring that hooks where I have indicated with the screw driver that pulls the lever down.
When I pull down manually it works. What makes it work? Is a spring missing? Can you help. The top screw drivers indicates that something attaches.
Cfroadhog
Re: Delux Mercury 1cent machine
Postby rosekiller454356 » Mon Dec 28, 2020 5:58 am
Yes there should be a small diameter spring that is attached between the top and bottom screw driver locations. The spring is appx. 1' long.
rosekiller454356
Return to Arcade
