Norris Masters Gumball casting needed
Postby Rick-okc » Tue Mar 06, 2012 4:18 am
I need the front coin entry casting for a Norris Master gumball machine.
I got one a while back but it doesn't fit. Apparently there were slight modifications to the castings.
If you look at the picture you can see slight diferences in the two castings.
I need the casting with the small vertical fin and the S-7 at the 12 o'clock position above the crank notch.
Rick-okc
Return to Machines Wanted
