Got it
Got it
Postby PA23 » Sun Jan 28, 2007 8:36 am
turns out ther was a small adjustment I needed to make on the coin head, probably moved the bar a fraction of an inch now everything works as it should.
I can see how finicky these machines were...
PA23
Re: Got it
Postby Dave » Sun Jan 28, 2007 8:27 pm
PA23 wrote:turns out ther was a small adjustment I needed to make on the coin head, probably moved the bar a fraction of an inch now everything works as it should.
I was just about to post a message suggesting that you look at the coin head and not the handle connections.
As you have found out, the coin head is VERY sensitive.
There are 9 coin sensors on the machine (6 for the points, one for field, one for 11, and one for the come) and if one of them is out of whack the machine will not function properly.
However, I have found that once you have the machine adjusted properly it will perform flawlessly.
