Nice machine; and interesting!
I agree with “Mills”; his comments on mech and cabinet seem correct.
The cabinet appears to be a reproduction; from the little we see of it, it looks too good to be original. But that is OK, if this machine was in shambles before it was restored; better to have a repro cabinet than a shabby one with cracks/breaks/missing chunks (assuming the original cabinet was beyond repair/refinishing). From the serial number, I would expect this machine to have had a dark cabinet with the stencil work on the sides. Does anyone know when mills started with the light wood?
Also, check to see if there are “nails” on back of base (or were they rods that went all the way thru for strength?). An original will have them; seems like repros often omit the back ones.
The mechanism appears to be correct; operating arm and lever are the early version. Evidence that payout slides have been changed as “Mills” suggests; the front stop is missing and the lever guide is a cut-down/short version; original would have had longer one with 2 holes in side (minor side note; lever spring should attach to hook on side of guide, not screw on base. Probably a replacement spring that was a little too long for hook.)
I would propose that it may have been an operator (not the restorer) who changed the slides; when machines were available with the higher payout, players would not want to play a machine with lower payouts, so operators may have upgraded the machine to get more play.
Yes; token parts are missing from escalator and mech (as well as 2 small vertical levers that check coins as they enter the escalator). These are parts often discarded by restorers, but again I would propose it may have been an operator who took them off. If machine was used in a territory where tokens were not used, an opertor may get rid of unneccesary parts to avoid problems. Certainly if machine needed maintenance due to a token part and tokens were not used on location, that part is gone.
Sounds like the seller is helpful; he should be able to tell you condition of machine when he got it and what he did to it. If someone else restored it, seller might be able to put you in touch with restorer to find out how much of it (castings, cabinet, bonnet, back door, cash box) was all together when it was found. Whatever history you get, be sure to write down and put in cash box; someday your grandchildren may find it interesting!
