jennings mechanical slot machine arm doesnt engage
Re: jennings mechanical slot machine arm doesnt engage
Postby miraclesanitation » Sat Oct 06, 2012 12:50 pm
Hello, Man it sure sounds like the mechanism is stuck half way down, Not sure if you watched the video yet. But if you google HOW TO UNJAM A JENNINGS SLOT PART 2 . there is a you tube video Dave shows how to cycle the machine or release the Mechanism if its stuck. Like I said my Jennings does this quite often where the handle goes loose and thats always the problem good luck
Darrell
miraclesanitation
Postby youngjedi » Sat Oct 06, 2012 4:06 pm
If you can take a picture of the handle side of the mech, i can take a look and see what's up.
youngjedi
Postby TJ » Sat Oct 06, 2012 7:35 pm
Check the care and repair post, you will find a reference to the answer to your jennings problems. T.J.
TJ
Postby ocbird » Sun Oct 07, 2012 10:24 am
SUCCESS! Dave's 'how to unjam' Part 2 did the trick. We used a screwdriver to get it to cycle and everything works again. You guys are AWESOME thanks so much!
ocbird
