New to slots - have a few questions
Re: New to slots - have a few questions
Postby tsparts4u » Tue Nov 13, 2012 9:31 am
Hi John,
Ok, for starters, the parts for the jackpot that I have been referring to as a shutter, is actually called a jackpot runway butterfly by Pace. Shutter is easier for me, so I will continue to refer to them as shutters, ha! Now... the only time that a coin should go down to the jackpot/s is when the coin tube is full, and an excess coin has been pushed off of the full coin tube by the coin tube overflow part. The only exception to that is, some machines had a mechanism to allow a coin to go into the jackpot when a cherry combination, usually a four coin payout cherry combination had been hit. Your machine most likely does not have that option. Now, as far as the shutters go.....let's assume, that both jackpots are empty. Those shutters are both in the open position. A coin comes down the chute. It will go into the first jackpot and the shutter will momentarily close as the coin is going through, and then open once again. There is no other mechanism to control the shutter. The shutter is hinged and it's weight acts as a counterbalance to keep it open. The only way it will close permenantly, is when the jackpot has reached it's capacity and coins are pressing against it to keep it closed. The second jackpot shutter will remain in the open position untill the first jackpot is full and then coins will begin to fill that jackpot.
Check out the drawing below for an example of the coin tube and the push off lever.
Regards,
Jerry
tsparts4u
Postby RameGoom » Tue Nov 13, 2012 11:35 am
Aah, OK. That piece is missing; the guard that covers the top of the mechanism. NOW...I need to fabricate one. That makes sense, resetting the two shutters. The only time in which they won't be reset to open is when coins fill the chamber and keep the shutters from opening. Then, once the coins drain from the jackpot, the shutter is then able to operate correctly.
Thanks for all the info, I will come up with a piece in which to cover the coin overflow area. Also, i can see I need to re-engineer the coin chute, since the one I have seems to have been whittled out of tin, and soldered together. The *real* chute must be a bit different and would obviously route the coins INTO the coin box rather than outside of it (where I'm finding coins at the base of the machine instead).
Thanks again. I'll keep you updated as I go. I have a OBJET machine where if I can develop a drawing on a part, I can make it out of plastic. I can see this machine will be fitted with parts like these...
John
Postby watlingboy » Tue Nov 13, 2012 1:54 pm
The casting on top of the coin tube would most likely have to be modified, added to or replaced when the conversion to the jackpot front was done because the coins originally just dropped into the coin tube, now they have to drop into the coin tube and refill the jackpot.
Postby RameGoom » Tue Nov 13, 2012 2:54 pm
I was wondering why that part was removed, but it makes sense; the coins drop into the jackpot chute instead of directly into the coin box. There is definitely something missing on that lower assembly, so I'll figure it out eventually.
I need to keep telling myself that there's a reason for those odd levers and springs, whatever it might be. You stare at it long enough, and it finally makes sense...!
John
Postby SLOT DYNASTY » Tue Nov 13, 2012 3:08 pm
John:
If you will e-mail me at slotdynasty@sbcglobal.net, I can put you in contact with a person that may be able to help you
with the parts you need for your Jennings/Pace conversion machine. He has been a parts dealer for over 40 years, and has many
odd parts, that others do not carry. He has helped me with several parts over the years. Good luck with your "fix-it" challenge.
That slash cover you need for the top of the coin tube, will be easy to make, if the correct one isn't available. Many of them are
made from bent tin, while others are castings. I needed one for a Mills "Poinsettia", which is cast brass, and couldn't locate one,
so ended up revamping a later model Mills bent tin example. It worked out just fine. Sounds like you will have your machine up
to par in no time, with all the help you have been getting in this thread. :)
Postby RameGoom » Wed Nov 14, 2012 6:13 pm
Well, that illustration helped a great deal. Apparently, my coins were bunching up at the top of the brass tube and it was because that feeder finger wasn't in its slot. Just hanging off the bracket behind the casting. So, I put it in there, and waa-laa, problem fixed. I fabricated a guard that screws to the two threaded holes where the long guard would normally be (I made a short piece because the coins go into the jackpot/coin box feeder).
Now I just need to figure out why the machine doesn't quite return to the "reset" point once it's played. The regulator starts, the arm with the gear and spring winds it, then unwinds it but not completely. This affects the payouts. In fact, it will prevent payouts unless the machine resets completely. Seems it could be a spring or something not powerful enough to return the mechanism to it's park position. If I manually pull the regulator arm to its stop, it will then reset properly and pay out if it's supposed to.
I'm close now.
Postby RameGoom » Thu Nov 15, 2012 10:39 am
I have this machine working *almost* right. The coin problem was fixed with a piece of perf strapping covering the coin launch path, directing the coin to drop.
The small lever in place, all's well.
The mechanism resets properly now that I oiled and greased every moving part in the bottom center of the mechanisms (that oil helps an awful lot).
Now for the payouts; they're inconsistent. Sometimes they pay out properly, sometimes not at all. I have determined that the payout slides need to be disassembled and cleaned. They appear to be sticking and hanging up.
Once I go that route, I'm ready for the next machine :-)
Thanks to all who responded to my issues!
John
Postby RameGoom » Sat Nov 24, 2012 7:46 pm
Finally figured it out:
