counterfeit gumball/vending machines?
Re: counterfeit gumball/vending machines?
Postby buzzojoe » Fri Apr 26, 2013 7:51 am
The biggest things that you run into with gumball/peanut machines are incorrect globes and incorrect paint jobs. You have to keep in mind that back in the day, Vending route operators weren't worried about keeping machines "original" for some collector 100 years from then. So when a globe got broken on location, they would put any globe that they might have in their shop that fit on the machine to get it earning them money again! That makes it kind of hard to figure out incorrect globes sometimes because a machine from 1920 might have had an incorrect globe put on it in 1921, which has been on there ever since....
Plus there are disagreements on certain machines as to what is correct and what isn't globe-wise. For instance, some "experts" say that Advance "Big Mouth" machines were ONLY made with large, "football" shaped globes on them, while others say that some of them came with round globes from the factory. And since the only two coin op "detectives" ( Bill Enes and Dick Bueschel) have both passed away, a lot of these questions will probably never be answered for sure.....
But then there are cases like the Atlas Ace I mentioned a few days ago on this forum, that is listed on Ebay as having "an original glass globe". It IS an "original" globe, but NOT an original Atlas Ace globe. It's a globe from a Silver King Machine, which is a very common and inexpensive machine. Globes for Atlas Ace machines on the other hand are nearly impossible to find. And if you DO find a "loose" globe for an Atlas Ace, you will pay nearly as much for it as a complete Ace is worth. So it appears based on the bidding that someone is going to end up buying the Ace on Ebay for a retail price thinking that it has the correct globe, and then will find out that they have a machine worth 1/3 rd of what they paid, and that they can't get the correct globe for it....
All you can really do is get the guide books and research machines BEFORE you buy or bid on them. Or look at pictures of the same model machine on the internet to see what the majority of them look like!
Regarding paint, the same thing is true regarding vending operators years ago. They ALL had a bucket of red paint, and when a machine came back into their shop for repair they would slap a coat of bright red paint on the machine. So it's hard to tell in a lot of cases what is correct and what is not.... Plus, although original paint is highly desired, it's easy enough to strip and repaint a gumball or peanut machine, and a nicely restored machine will bring almost as much as a clean original. Just be careful because some of the powder coating powders are getting SO good that they look just like porcelain. Some machines were available in either porcelain or regular paint. Obviously the porcelain ones are worth a LOT more than the painted ones. Just remember that unless it's been literally stored away since day one, porcelain coated machines are going to have SOME kind of damage. A chip or some spider web cracking or some stains. If the seller is claiming that it's porcelain and it looks PERFECT, it's probably just really good powdercoating. And I don't know of a way to test it without scraping it with a knife. And no seller is going to let you do that.... There were also very few colors of porcelain back in the day. So if the machine is pink, it's probably NOT porcelain!
You also have to use common sense regarding "Themed" machines. Did John Deere or Harley Davidson or Budweiser make (or have made) gumball machines wit their logos and paint schemes on them back in the 1920's and 1930's. NOPE! So if you see a Dr Pepper or Sinclair Oil themed gumball machine and you want it for your "man cave", GO FOR IT! But understand that what you are buying is more than likely a very common, $40.00 machine with $5.00 worth of paint and decals on it, and NOT a rare and original collectible!
If you post to this forum, buy the reference books like Silent Salesman and the pocket guide to gumball machines, and look at websites like Crow River Trading to see what original globes look like and if they are available new or used, you should be ok when buying machines for your collection!
buzzojoe
Postby nvmos2 » Wed May 01, 2013 5:26 am
Ref: the Atlas Ace on ebay; sold for $307.99 plus $24 SH.
I contacted the buyer yesterday to make sure he knew the globe was incorrect since the seller wasn't upfront with his listing.
Have not heard back from him.
Ref: Correct gum machines;
I'm sure most guys know this, but for the newbies;
there is an older (1981) book from Mead ;
"Gumball Machines (Right or Wrong" by A.V.Vilst
edited by Phil and Julie Cunningham.
It's not put together very well, but has a lot of good info, mostly centered around correct globes.
Looking thru it, one would think very few machines are found with the correct globe on them.
I sold a copy of the book on Flebay several months ago for about $30.
Postby buzzojoe » Wed May 01, 2013 10:01 am
It will be interesting to see if you hear from the buyer. I'm also surprised that the seller of this machine puts a "doctored" email address in his descriptions and doesn't get caught. But that's between him and ebay :^)
buzzojoe
