5/25 coin machines
Re: 5/25 coin machines
Postby Dave » Tue Apr 02, 2013 3:34 pm
OK. Here are some photos of my 5/25 Rol-A-Top. The machine is all original and in decent shape. At one point in time I thought about restoring it. However, after talking to several other collectors they all advised against it [-X . The rationale was that by leaving it original there would never be any doubt about it being a legitimate 5/25. Once it was restored people might question it and in their opinion the machine is worth more in its current condition than it would be after it was restored. Original Rol-A-Tops are hard to find and an original 5/25 is next to impossible.
First, here is the machine itself.
Here is a closeup of the escalator with the machine still in the case. Notice the escalator frame is different than a regular Rol-A-Top frame. There are cut-outs for the special 5/25 hardware.
Here is a shot of a non 5/25 Rol-A-Top. Notice the frame has no cutouts.
I have been told that the cutout frame is not on all 5/25 Rol-A-Tops but having it definitely proves it was not converted.
Now, here is a photo of the escalator with the machine out of the case.
You can see the special hardware needed to make the 5/25 machine. There are basically two levers.
The horizontal lever is tripped on the first pull when a quarter is played. Because a quarter is wider than a nickel, the quarter will hit the horizontal lever which will then cause the vertical lever to lock the horizontal lever in place for the next 5 pulls. When the horizontal lever locked it will block the coin detection lever from moving forward which will make the Rol-A-Top think a coin has been played.
On the 5th pull the quarter will trip the vertical lever which will release the horizontal lever thus allowing the coin detection pin to operate as normal and block the machine from playing until a nickel or a quarter are played.
Postby andydotp » Tue Apr 02, 2013 3:43 pm
Terrific post Dave, thanks.
Afraid I cannot locate the article I mentioned earlier but Dave's pics above better illustrate this clever machinery.
andydotp
andydotp
Postby CoinOpBuyer » Wed Apr 03, 2013 9:08 am
I am glad you did not restore that machine. I agree with the people you talked to. I think an original 5/25 is more desirable and valuable than a restored one.
Is this machine for sale?
You need to be really careful with restored machines. If you buy one that is restored ask if they have a before and after photo to make sure major parts have not been swapped.
A long time ago I bought a restored Rol-A-Top that vended mints at the Chicago show. It did not have fortune strips. I did not know better to ask.
I later found out that it should have had fortune strips and someone must have changed out the bottom casting. I removed the bottom casting to inspect the case and I saw holes in it where the original casting was married to the case. The holes were filled so it was not obvious by looking at the outside.
I felt I was deceived.
CoinOpBuyer
Postby markus » Wed Apr 03, 2013 12:13 pm
Dave:
Excellent post. It helped me a lot! Thanks.
markus
markus
Postby marsonion » Wed Apr 03, 2013 12:30 pm
There is a 3-4 pgs. article on the Rol-A-Tops authored by Bueschel appearing in Vol.I Issue1 of Loose Change which, naturally, mentions the 5/25 machines, but it certainly doesn't go into any great depth about them. Is this the article the posters on this thread are alluding to? I have that issue if anyone's specifically interested in what it says there on the subject...
Postby andydotp » Wed Apr 03, 2013 10:16 pm
Well found marsonion, I do believe that might be the article I alluded to. Will have another dig around.
Just my luck huh? - Volume 1, Issue 1, I gave up about half way down my pile as I worked latest-down in chronological order. :D
andydotp
andydotp
Postby Dave » Thu Apr 04, 2013 8:30 pm
Someone asked me to explain how the machines separates the nickels and the quarters.
Ya know, that is something I have never really thought about and the mechanism was still on my work bench so I went down tonight to figure it out.
As expected, it is amazing simple. I removed the slug diverter shoot to make it a little more obvious.
When the coins leave the escalator they trade straight down towards the coin tube (as one would expect).
However, the path then restricts so that only a nickel can continue. A quarter will get stopped. At the stopping point is a pin which is retracted when the handle is down. When the handle (mechanism) is returned to the at rest position the pin comes out and pushes the quarter out so that it can be directed to the cash box.
There is a hinged U shaped diverter that keeps the nickels from accidentally following this path.
Here are some photos to help see what is going on.
My finger is pointing to the path that both nickels and quarters follow once they leave the escalator.
My finger is pointing to where the quarter will stop. The mechanism is not at rest so the diverter pin has been retracted (allowing nickels to fall straight down).
Here my finger is pointing to the pin which kicks the quarter out. The mechanism is at rest.
This picture shows a quarter that has just left the escalator but its travel has been halted because the path it was following just became too narrow for the quarter. The mechanism is not at rest to the diverter pin is pulled back.
I am holding the coin against the diverter pin so you can see how it ejects the quarter. You can see the hinged U diverter which keeps the nickels from accidentally taking the quarter path to the cash box.
One last shot showing the diverter pin after the quarter has been sent to the cash box.
Hopefully I have explained how the nickel and quarter separation are not.
If not let me know and I will try to be more clear.
Postby Dave » Fri Apr 05, 2013 9:05 pm
OK. A few more photos. Someone sent me an email asking for pictures of the backside of the escalator.
Here they are. I also took some photos showing the quarter kick out pin.
Postby andydotp » Mon Apr 08, 2013 12:04 am
Found it!
Loose Change, December 1993.
Article by Anna Karine Neal with detailed pics & explantation of the Multi-Coin Rol-A-Top escalator.
Dave's pics are superior though.
andydotp
andydotp
