Watling Blue Seal Twin Jackpot
Re: Watling Blue Seal Twin Jackpot
Postby flipper77 » Sun Jul 28, 2013 12:26 pm
Hi Gene.
Yes, your machine is identical to my Watling in the jackpot chute and coin tube feed. You are correct in that a full coin tube causes the kicker to rake off the coins that just go to coin box - the jackpot chute is higher on the mech. If you see no lever or arm that can push the flap up to direct the coin into the jackpot chute, not sure what you do next. You probably already have done this but I would make sure that the coin tube is full to overflow just to see if that might activate a rod or lever to move the flap up. If that flap is on your machine, that was how the jackpot chute is fed and there must be (or must have been) something to activate that flap. Sorry - wish that we could offer more help.
Flip
flipper77
Postby watlingboy » Sun Jul 28, 2013 1:27 pm
O.K., I think I see the problem. Flip needs to take a picture of the back of his head. That is where the problem is. You are missing a part or more that moves that flap up to divert the coins to the jackppot. Can't remember exactly how it works. Might work off the slides and when 2 cherries and a lemon are hit, it diverts to the jackpot, like a Caille Superior fills. If you look at the back of your head, on the right you can see a boss which looks like a shoulder bolt is screwed into it but nothing is attached.
Postby gsx11r » Sun Jul 28, 2013 1:28 pm
Hi
Look at this address ! Picture 43 !It s the link for push the Flap !
http://www.joiret.com/watling/blue-seal/demontage
Hope that you have this link ! That will be hard to find !
Stephane
gsx11r
Postby METALRAILS » Mon Jul 29, 2013 4:28 pm
I don't think this slot ever had that set up. Besides the involved linkage, that method uses a cam that probably operates the linkage every 3rd or 4th pull. My slot doesn't appear to ever had that cam, nor a place to mount it.
Does anyone know what the rectangle part of the frame near the 1st reel disk with the 2 threaded holes is used for? Perhaps a 3rd method to push the jackpot coin flap?
Gene
METALRAILS
Postby watlingboy » Mon Jul 29, 2013 5:58 pm
That picture that Gene posted, I believe, is a foreign export machine. I have never seen that cam system on an American Watling before. Let me know if someone else has seen it.
Those two holes you asked about, are for mounting a gold award trip bar. If you machine had gold award, that's where the sliding trip bar goes.
Someone need to post a close up picture of the back of the head and also the jackpot diverter from the back.
Postby flipper77 » Tue Jul 30, 2013 6:30 am
Here are two pictures of my Watling Twin Jackpot with the rod that actuates the flap to feed the jackpot. Hard to snap a photo as deep in the mech - my flashlight got in the way of one of the photos. But this is of little help to Gene if his machine never had the Rube Goldberg cam system that activates every fifth coin. Does anyone else have a Watling from this era that activates the jackpot flap differently and can snap a pic?
Flip
flipper77
Postby watlingboy » Tue Jul 30, 2013 8:57 am
Flip,
Sorry for the inconvenience of taking the picture. I was thinking you had the version without the Rube Goldberg mech. No, that won't help Metalrails. Someone will have to take a picture of the other version.
Watkingboy
Postby gsx11r » Tue Jul 30, 2013 9:51 am
watlingboy wrote:Flip,
Watkingboy
Hi
Go to this link !!I can not found better for have picture of the second version !!!!
http://www.joiret.com/images/phocagalle ... e_seal.jpg
http://www.joiret.com/watling/blue-seal/remontage
Thank you Jean-Paul !!! :wink:
Stephane
gsx11r
Postby METALRAILS » Tue Jul 30, 2013 10:15 am
Hello all,
Thanks for all of the pics. I don't think my slot ever had either version. There just isn't evidence of any mounting holes etc.
Now begins the hunt. Probably the proverbial needle in the haystack!
Gene
METALRAILS
Postby gsx11r » Tue Jul 30, 2013 1:26 pm
Yeap !!
I think that your Mechanical is a “Frankenstein Mech.” !
The Right Frame have certainly been destroyed !!And replace with one from a Treasury Mech. or a blueseal last generation !!
I have never seen a 10 stop reel with the “square “ for the gold award ! It s impossible "for me "!!
But you just need to find a poor blue seal Mech. for complete your !!
Or you can complete the jackpot with the hand anyway you will never won it ! :twisted:
Good luck !!!
Stephane
gsx11r
PreviousNext
Users browsing this forum: No registered users and 32 guests
