Questions about my Rol A Top
Re: Questions about my Rol A Top
Postby watlingboy » Sat Oct 05, 2013 3:23 pm
In the future if you have a problem with a Rol-A-Top mech, remove the arm which connects to the operating arm on the side of the mech. It goes up and connects to the escalator. Is is connected with a small washer and a cotter pin. Pull the pin and remove the arm, you can let it hang free. Hold back the arm with the coin detecting pin on it and cycle the mechanism. If the mech functions properly, then you know the problem is in the escalator. This also allows you to turn the escalator and track down what problem might be there. This needs to be done with mech out of the case.
As far as your additional problem, while the internet is great, it is not a cure all. It is going to be very difficult for someone to fine tune your mech over the internet. If it was sitting in front of me, it would probably be easy to detect the problem and fix it but it could be a few different things and difficult to try to explain to someone not familiar with slot repair. It could be as simple as the square 1/4" piece of stock on the main operating arm that needs adjustment. You should try to find someone who does slot repair in your area and let them fix it.
Good job on what you have already fixed.
Postby Midcoast Vintage » Sat Oct 05, 2013 4:50 pm
there is a knowledgable slot collector / mechanic in the houston area named oscar schneider.
Postby SLOT DYNASTY » Sat Oct 05, 2013 6:22 pm
Midcoast Vintage wrote:there is a knowledgable slot collector / mechanic in the houston area named oscar schneider.
Absolutely.....Oscar is the one to contact. He is in Houston, and does know Watlings to a certain extent. If you cannot solve your
problem with all the little tidbits here, and feel you need his help, drop me a PM, and I will send you his landline. He does have
another home in Texas, so may not be available at a moments notice. Bill
Postby kingsley » Sat Oct 05, 2013 9:47 pm
I will call Oscar.
Watlingboy, you said:
"It could be as simple as the square 1/4" piece of stock on the main operating arm that needs adjustment."
That bar is the area where it is binding. I looked at it earlier today and saw that the back side of the bar is flush with the piece it does through. To adjust it would I move it forward or backwards (assuming it will not do any harm to the machine to try.)
kingsley
Postby watlingboy » Sat Oct 05, 2013 10:23 pm
Here's where it gets tricky. The adjustment of that bar is important to two major functions which take place during the play cycle. It is not as simple as moving it forward or backward, although you can do that, it is a matter of how far in or how far out you move it and getting it in the correct spot. It would be easier to explain it over the phone instead of in print. If you want to private message me your phone number or your email address and I will give you my number. Having the bar flush seems about right but you can't tell by that, it differs, sometimes it is in more and sometimes it is sticking out. And judging from what you have described, the piece of stock if it needs to be moved at all will need to be moved back and not in.
Postby kingsley » Mon Oct 07, 2013 5:46 am
Well I got it working with the help of the board and especially Watlingboy who talked me through it. It still has this slight hitch and I will contact Oscar and see if there is any fine tuning he can do but other than that it does its thing. Thanks for all the help.
kingsley
