Caille Ben Hur - Advice Needed
Re: Caille Ben Hur - Advice Needed
Postby watlingboy » Fri May 09, 2014 10:02 am
I have owned a couple of Ben Hurs and the handle on those is different from a normal slot. After the machine is played, the handle stays down until the wheel stops and the play is finished and then the handle returns to the up position as opposed to most handles which start the return as soon as the mechanism is tripped. So check to see why the handle is not returning after the play.
Not a clue as to why it would not pay off when all colors are played. This is not what is causing your problem but when you play all 6 colors in a 25 cent and 50 cent Caille floor machine, they will sometimes get clogged because you have 6 large coins being released and all going into a funnel and depending on how they land, this can cause a clog. Although you should be able to play all the colors at once, in real life I don't think the Caille floor machines were ever played very often with all colors played or that the manufacturers thought they would be played like this. Not with a 50 cent piece being worth approximately $10 in todays money at the time the machines were new. Hopefully someone else can look at your mech and help you with the pay off problem.
Postby mechanic » Fri May 09, 2014 11:43 am
Marky Here's another check you can do, see if the pump goes down in back of the mech, if not it could be the pump is frozen and may need to be lubed or a spring is gone. This may also fix the payout problem since it seems the machine is not completing its cycle sometimes when you fix one problem the other clears itself. I have faith you will find the answer!!!!!!!!! Good Luck
Postby markymarkuk » Fri May 09, 2014 2:54 pm
Here's the photo of the inside of my machine. So when played, I push down on the handle, wheel spins, and pays out if winning coin and color hit! But the handle does not rise up. On the next play, I drop a coin, if I simply lift handle if just drops back to bottom. So what I have to do is push the handle down a fraction (theres a little down movement there), something is heard to click inside, then the handle springs back to the top.. and I can now push down to spin wheel as normal.
I have indicated on the photo a vertical lever that does not appear to come to the top after play, it seems to stop. the click I hear is when I push the handle down a fraction before play, appears to release this and it slides upwards... confused? I am?
Hope you can tell what model I have from the inside mechanism.
thanks
markymarkuk
Postby watlingboy » Fri May 09, 2014 3:10 pm
Handle isn't going down far enough for the cog to clear and reset the handle. Pull that piece of rubber out that the handle hits when play the machine. It's in the casting that the handle goes through on the front of the machine. With the rubber out, play the machine and see if the handle comes up. If so, just trim the rubber, cut it in half the thickness.
Postby gsx11r » Sat May 10, 2014 1:45 am
Hello
I will try to make my best with my poor English !! (sorry)
The Bar “A” release your arm at the end , only when the cycle is finish !
But for this , be sure that the Bar “C” never touch the Bar “B” when the cycle is finish !!
Twist (a little) the upper of the bar “C” for this !!
About the 5 coins at the same time , I don t know , you don t have the part that be able to make this !! So , please ,insert 5 coin , pull the arm , be sure that you don’t received any coins ,don’t touch anything , TAKE a picture !
I think that your “Commercials” is an English version !!
Let me know !
Stephane
gsx11r
Postby markymarkuk » Sat May 10, 2014 6:12 am
Many thanks for the help guys.
Stephane thanks for the description of how it works, and your idea about twist bar C looks as though the previous owner has done this to miss hitting the bar B. I will have another look tonight and see if thats whats happening. I'll also try the suggestion that the handle is not travelling down far enough, Oh hang on, as I write this I've just realised that the mech not resetting happened too when out of the case and I manually pushed down on the play arm, so that probably rules out the rubber stopper I guess.
I'll check the bar B and C issue.
I'll look at the 5 coin issue once this is sorted.
markymarkuk
Postby markymarkuk » Sat May 10, 2014 2:54 pm
Here's what I know from just looking and testing, tell me if Im wrong.
I took the mech from the cabinet and pushed the handle down, but it still got stuck at the bottom.
When the handle is pushed down, the large cogged wheel moves anti-clockwise (viewed from rear), the red bar rises up above the teeth of this wheel, when the handle is at the bottom the end of this red bar drops in to the last tooth (see my picture, blue arrow) and so stops wheel from returning clockwise, and so lifting the handle does not occur. From what I can make out, as the mechanism un-winds - see picture, the green arrow pushes up on the bottom part of red bar, and I'm guessing is supposed to force the Bar out of that last tooth to allow the handle to return.
This does not happen, so on the next play, I push down on the handle, it turns the cogged wheel just a fraction, this is enough to force the bar catch that is dropped in the last tooth to be forced up and free the toothed wheel, and so the handle springs back to upright position.
Hope that helps... Any advice now?
Wheel locked by red bar
Lever is pushed up to release red bar
markymarkuk
Postby gsx11r » Sun May 11, 2014 4:29 am
Hello
That s the good way !!
now , replace the spring "A" with one more flexible(soft) ! at this time , He must be too "strong" !
He must be softer than the "B" !!
Stephane
gsx11r
Postby Midcoast Vintage » Sun May 11, 2014 11:46 am
another one of these machines has just been listed on ebay.
http://www.ebay.com/itm/Antique-1900s-C ... 3ce117b5f3
Postby markymarkuk » Sun May 11, 2014 3:19 pm
Thanks, the spring is very strong.... I'll replace. Love your picture of the mechanism nice and clean!!
markymarkuk
PreviousNext
