How do double jackpots work?
Re: How do double jackpots work?
Postby oldslotman » Thu Oct 23, 2014 10:10 am
Those jackpots with reserve can be very touchy trying to get them installed correctly.
Postby WikiSlots » Fri Oct 24, 2014 6:44 am
Based on the info you posted, I was able to figure it out. I've got to take fault for putting it back together wrong in the first place ... that was all me. But, the second attempt was successful based on your great info.
You're right about it being tricky. The key is to get the upper door to rest in a two-prong fork lever and then hold the door from falling forward when the jackpot is installed onto the glass. The door can fall forward off the fork and a spring pulls the fork back up. It works perfectly now.
The glass is an illusion ... it looks like there's a gap that dimes can fall down into, but it's just the thick glass. Cool.
My next fix is to work on the pump ... the handle slams back into place. I think that's an easy adjustment. And then that should do it ... got the original lock and cash box, so it should be 100%. Now I know why machines are priced so high ... they take a lot to get them to 100%, not just functional.
One more follow-up on the orange machine, even though the paint looks to be over 40 years old, I noticed the front was nickel-plated before painted orange. If that was not common in 1932, then I would assume the machine was refurbished in the 1950s.
-Dave M
WikiSlots
Postby oldslotman » Fri Oct 24, 2014 9:47 am
Great, glad you able to figure it out. You got the tricky part right.
Users browsing this forum: Google [Bot] and 4 guests
