How do side venders connect to mech?
Re: How do side venders connect to mech?
Postby WikiSlots » Thu Nov 27, 2014 2:41 pm
May I ask ... what is the purpose of 1205CSP and 1158?
WikiSlots
Postby altort » Thu Nov 27, 2014 6:26 pm
This is an other version of that trip lever on a four column FOK, I had an other but might have gotten rid of it cant find it.
I have not spent any time on this mech but I believe that it works in conjunction with the check detection lever and depending whether a coin or check was played it will keep from paying out.
Postby rtmccurdy » Fri Nov 28, 2014 10:38 am
Hi. Could someone please post a picture of the mechanism side for a Castle Front with side vendor? Thanks!
rtmccurdy
Postby watlingboy » Fri Nov 28, 2014 12:29 pm
I think it was Stephane who posted pictures of the inside trip bar which mounts to the cabinet. He posted these within the last 2 weeks. I don't know if it is a Castle Front but it doesn't matter as all the Mills of this period were the same.
Postby rtmccurdy » Fri Nov 28, 2014 1:06 pm
I have all of the inside cabinet linkage (side vendor mounted and cotter pinned). I just need a picture of the left side of a late 1930's mechanism for part reference.
rtmccurdy
Postby rtmccurdy » Fri Nov 28, 2014 1:15 pm
I see now. The OK side picture from Stephane is the same through the '30's?? (I might be missing the 405 knife)
rtmccurdy
Postby watlingboy » Fri Nov 28, 2014 2:51 pm
If the knife is the part you are missing, that should be easy to find. Watling put that trip knife only on machines that had venders. Not so with Mills, because you could add a side vender to Mills, they put that trip knife on every mech whether it left the factory with a vender or not.
Postby WikiSlots » Thu Dec 11, 2014 12:23 pm
Well, I'm sure I'm doing something wrong.
Okay, so I've got the trip lever on the cabinet and the new part for the mech. What's happening now is ... the trip lever rubs up against part 1154 preventing it from pushing completely down to trip the vender and from returning fully back up to the up position. When the trip lever goes down, it actually goes slightly forward towards the front of the machine. As a result, it actually pushes harder against the vertical part 1154, thus making it even more difficult to go down and come back up.
Any ideas?
[-o< Dave M
WikiSlots
Postby WikiSlots » Thu Dec 11, 2014 3:26 pm
OMG ... I am such an idiot! #-o :oops: I'm embarrassed to report that I did not have the mech completely in the cabinet. I thought I did, but I realized, I hadn't put the side arms down to secure it in place. All works fine.
I'll also report that after looking at the part 1154, I now realize that is the check detector arm that pushes the coins into the box (or slips through the center of the check). Once forward, that also pushes the bottom check lever to prevent mints from being taken. Hats off to these early inventors!
=D>
WikiSlots
