Gottlieb deluxe 3 way Strength Tester
Re: Gottlieb deluxe 3 way Strength Tester
Postby integ194 » Fri Feb 06, 2015 3:57 am
Thks Al-their great pics. Just one question pls: what is the diameter of the coin hole? Kind rgds Wayne
integ194
Postby altort » Sun Feb 08, 2015 8:39 am
Wayne the diameter of the coin hole is 1-1/4", just let me know what else you need, did you get your machine yet and get get a chance to asses the condition?
Postby integ194 » Sun Feb 08, 2015 9:44 pm
Thks Al much appreciated. The machine is scheduled to be delivered Wed 11 Feb 15. I will post pics similar to your original post. Best rgds Wayne
integ194
Postby integ194 » Mon Feb 09, 2015 4:18 am
The tester was received from the US today via the ebay global shipping program. I am conscious that this program has been severely criticised in some quarters but I found it very good. US to my residence in Australia in under two weeks.
I will post more pics in the next few days but my assessment of the tester is as follows:
-cabinet requires some straightening at rear top & backplate missing but otherwise is sound;
-dial and dial mechanism appears ok ( I have ordered a Crow dial & decal repro set);
-grip handle & arms ok but will need refinishing and one arm has a broken screw which will need to be extracted;
-coin insert broken in transit due to poor internal loose packing;
-coin mechanism missing but I have purchased replacement including coin insert topper;
-pic below reveals mechanism parts which are broken. The main coin tiller, pendulum & screw adjuster section is broken in four parts (including missing pendulum and bracket) and I doubt whether it is redeemable. The swing arm is broken and missing a section. The component which draws the tension spring is broken but I believe may be fixable. The bell mechanism seems to be ok.
I note that to remove the grip mechanism two pins need to be removed. I am anxious to understand the best manner of achieving this removal.
integ194
Postby CoinOpNut » Mon Feb 09, 2015 3:18 pm
Hi Wayne -
Now that the machine has arrived the fun can begin!
The pins you are referencing are just taper pins that are best removed by grabbing with a good pair of long-nosed pliers and extracting.
They serve an important function of keeping the start point for the mechanism for the coin release lever to be aligned under the coin chute - so keep those pins in a safe place.
On the broken parts - the central casting that holds the coin lever and the spring tension adjustment is a common one to fail. I hope others on the forum can search their parts stash to see about locating one. I will check mine and let you know.
If you have any other questions on the assemblies let me know.
-J
CoinOpNut
Postby SLOT DYNASTY » Mon Feb 09, 2015 4:23 pm
integ194 wrote:.
Hi Wayne:
Most all pins that secure handles and other parts to shafts, are Taper-Pins. If the original pins are still intact,
they will be flush on either end, and not sticking out, to grab with pliers. A Taper-Pin, (as to why it is so named),
only goes in & out, in one direction. Usually downward, if it is through a handle. They have to be knocked out
from the smaller end with a drift, and replaced in the same manner. Apparently many pins get lost or misplaced
during machine dismantling, as I have seen all sorts of things used in reassembly. Usually large nails. I just had to
replace one in a handle, that someone had used a large 8P or 10P finishing nail, and it wasn't anywhere near tight.
Wish I could help you with your other needs, but do not have any parts for this type of machine.
Postby integ194 » Mon Feb 09, 2015 7:17 pm
My thanks to John & Bill for advice on removing the pins. All done & I found once I removed the dial section that improved access & pin removal was facilitated.
I have now completely disassembled the tester and that certainly has enabled me to better understand the logic of the mechanics & pics are attached.
1. the cabinet will require straightening on the rear topside;
2 the gripper & arms are ok although one arm (arrow shows) has a broken screw embedded which will require removal. I do not have these screws so if someone is able to let me know the thread type that would be great;
3.the rear of the glass cover plate casting has a number of hair line cracks around the screw holes-not sure how common this is. I might try a fine layer of 'cold weld' for reinforcement;
4.I note the bell tends not to ring but to 'docile dong'. I suspect the crack in the bell is the culprit.
My previous post has highlighted aspects of the mechanism which are missing or broken. If anyone has any of these components for sale pls let me know.
I really appreciate the support of the coin op community. :D
Rgds
Wayne
integ194
Postby integ194 » Sat Feb 28, 2015 6:06 pm
An interesting ebay listing for a tester has just occurred where the seller indicates it 'works'. Well???
http://www.ebay.com/itm/Vintage-Grip-St ... 1619185309
integ194
Postby SLOT DYNASTY » Sat Feb 28, 2015 10:32 pm
integ194 wrote:An interesting ebay listing for a tester has just occurred where the seller indicates it 'works'. Well???
I wouldn't waste my time with this one on eBay. Maybe it does work, but not very well. It appears to have much rust
in the mechanism. If you just want some parts to put in a drawer for future use, that's about all it's worth. It is not
the same model as yours, and doubt if any of the parts are interchangeable. The case is bent much worse than yours,
and has a busted-up base plate. No back door & lock. One handle missing. Gripper is a different style. It does have a
nice dial & pointer, but still will not work in yours, as the gripping capacity has a much lower rating.
