How many coins to operate slot machine?
Re: How many coins to operate slot machine?
Postby Dave » Sat Feb 07, 2015 9:12 pm
White lithium grease?
I have bought machines where the person who restored or worked on that machine 15+ years ago used that stuff and it turned into concrete.
I found a grease called "Blue Grease" which works great. I can't find it anymore and don't know what I will use when my supply is gone. Machines that I used it on 20 years ago still work great.
Postby DeTrana » Sat Feb 07, 2015 9:37 pm
Vaseline was what the original instructions to operators stated. I use tri flow as well. I agree the white grease solidifies in time.
DeTrana
Postby SLOT DYNASTY » Sun Feb 08, 2015 4:11 am
I have used both types of Vaseline on most all small parts, in both slots and trade stimulators for many years,
with never any problems. There are more than one type of white grease, and yes, some are not good for long
term use on machine parts. I have found some of them coagulated with age, just like some of the darker ones,
and the parts become glued together. The best all-around light grease for the heavier parts on machines, that
I have always used, is Lubriplate. It is made in the U.S., and is a blend of mineral oil, calcium, & zinc oxide. It
can be used sparingly, and does not thicken with age.
Postby hlhopp » Sun Feb 08, 2015 5:15 am
Thanks to all for the great advice!
This is my first antique slot machine and it seems to be all original except the door lock doesn't say Mills on it, the key has CCL on it. I want to keep it lubed correctly so it doesn't bind and break anything. When I lubed it because it wasn't paying out I just lubed the clock gears and the block that holds back the payout mechanism. It slides out of the way so the payout slides can snap and I think was dry and dragging, slowing down the clock. Works fine now! Didn't get any lube on slides. I actually used a quality automotive wheel bearing grease that I had.
Can a person put photos on this forum? If so, how?
Thanks again,
Harry
hlhopp
Postby sambow88 » Sun Feb 08, 2015 8:43 am
Looks like a lot of us have different ideas for the best grease to use so I thought I would throw in my two cents. Several years ago I found what I believe is the best for my machines. The product is called Super Lube®. It's a synthetic lubricant and looks a lot like Vaseline. It goes on cleanly and doesn't harden as for as I can see.
For a complete description just Google "Super Lube" and go to their web site.
This is the best thing I have found and wanted to share it with all of you.
sambow88
Postby hlhopp » Sun Feb 08, 2015 8:52 am
Ok,
Thanks TheFatman, I'll try to put a photo of my new machine on here!
The inside with a lever wired up....center left of photo.
My freshly unpacked Black Cherry!
hlhopp
Postby hlhopp » Mon Feb 09, 2015 6:20 pm
Thanks for all the response on my question of how many coins my machine will take.
I experimented today and found out exactly how many coins it takes to fill a 5 cent Mills Black Cherry machine. I emptied it twice and refilled manually. It averaged 120 in the payout tube, 80 jackpot, and 50 reserve for a total of 250 nickels.
It's really working great!
Harry
hlhopp
Postby TheFatman » Tue Feb 10, 2015 12:15 pm
I am very glad to hear that it all went well. =D>
dave F
