Question about REEL STRIPS
Re: Question about REEL STRIPS
Postby RameGoom » Thu Mar 05, 2015 5:00 pm
Bill, the image above also shows the serial number, for your files.
From all the images I have found online, it definitely looks like a standard Poinsettia, except, well, the paint schemes are all over the place. So I'm not even sure exactly what the correct paint should be - probably over the years, thru various owners, the painted casting gets modified on occasion.
So, my thought is that there really is no "factory correct" with this particular model.
John
Postby watlingboy » Thu Mar 05, 2015 7:23 pm
If you look at any of the old Rockola ads, you will see that they sold brand new machines, used machines and jackpot conversion fronts. I would imagine they put their decals and reel strips on used machines they sold for advertising purposes. They didn't modify the majority of machines they sold with revamped castings. They put their name on them and sent down the road.
Keeping the original strips or replacing them with the correct tin strips does increase the value, in my opinion. I will sometimes pass on a machine if tin strips have been replaced with paper.
Postby SLOT DYNASTY » Fri Mar 06, 2015 4:27 am
RameGoom:
Your Mills "Poinsettia" machine above, is the most common variation of them all. The next
closest variation to this, is only in the jackpot window casting, with either the 'jail-bars',
or the two different styles of criss-cross bars. All the different jackpots, were also present
with all the other design changes.
There was also a Pace revamp model, that had a design change, which had a butterfly in
the casting. Jennings made 2 or 3 "Poinsettia" models, which also had a butterfly design.
Postby MONTI » Fri Mar 06, 2015 10:41 am
watlingboy wrote:If you look at any of the old Rockola ads, you will see that they sold brand new machines, used machines and jackpot conversion fronts. I would imagine they put their decals and reel strips on used machines they sold for advertising purposes. They didn't modify the majority of machines they sold with revamped castings. They put their name on them and sent down the road.
Hey Watlingboy, is this George?
If it is we haven't talked since you bought the Caille Big Six Quarter and Nevada Lodge Sun Chief Floor console from me back in the early 90's, wish I had kept that Caille Big Six, worth almost 3 times what I sold it for back then!
16 MONTI CAILLE.jpg (24.2 KiB) Viewed 4365 times
Hope all is well with you and if this isn't George, press delete! :D
Ciao,
Monti
