columbia help please?
Re: columbia help please?
Postby marsonion » Mon Aug 10, 2015 8:15 am
pj waelti wrote:This is a pic of the back of the machine pj
I can barely see the screw-hole where the "'pivoting' 'vestibule' 'gate'" linkage assembly mounts to the vertical arm that carries the U-shaped bracket, so I doubt that your situation reflects any variability of manufacture. I'm afraid those parts got "monkey-jacked" into a can years or decades ago, and I'm amazed your machine cycles at all. Let's pick this up by phone , PJ-- I have a call in.
Postby pj waelti » Mon Aug 10, 2015 10:35 am
more pics
pj waelti
Postby marsonion » Mon Aug 10, 2015 11:56 am
pj waelti wrote:more pics
Do you have the indicated part? It is the business end of the "Coin Shutter," which is designated as "A-173" in the parts list.
Postby TJ » Mon Aug 10, 2015 1:26 pm
They are out there and for the most part are fairly reasonably priced, find a good one buy it and you will have more fun than you can imagine. Remember the one that works don't fix it.
TJ
Postby pj waelti » Mon Aug 10, 2015 2:33 pm
Well snookered again, My machine has none of those parts. No wonder it tries to double up the coins. Any ideas on finding those parts? PJ
pj waelti
Postby marsonion » Mon Aug 10, 2015 2:37 pm
pj waelti wrote:Well snookered again, My machine has none of those parts. No wonder it tries to double up the coins. Any ideas on finding those parts? PJ
Call or PM and I'll give you Bud Gott's phone number, etc. (I think his contact info might be posted on some other thread here-- try a quick search.)
Postby pj waelti » Mon Aug 10, 2015 7:42 pm
Here's a pic of the machine cabinet. I think Bud might have all the parts I need, hopefully anyway. Fingers crossed for luck at this point.. PJ
pj waelti
Postby marsonion » Sun Oct 18, 2015 11:17 pm
pj waelti wrote:Yes that is what I was looking for. I have the machine somewhat working except for one thing. When it pays out it pays the correct number of coins, then on the next pull the coin carousel moves clockwise a little causing the coin to go into a slot already occupied with a coin.
It makes this move at the same moment the the handle is about to release the mech to make the reels spin. This causes a jam. It does not make this move any other time other time, only after a payout. This is a cool piece of engineering but has got me to get up and walk away from it frequently. I was warned to stay away from these machines but just could not resist the urge to own something different. I'm sure I'll get it eventually but I might have to rely on help for this problem.. Thanks for the help marsonion, PJ
There was something about this particular malfunction that stuck in my craw. I knew I'd seen it before, somewhere... but didn't recall what I did about it. Now I have another one in here, and it all came back to me! #-o
The sudden clockwise movement of the carousel during the pull-of-the-handle is most directly caused by the recoil of the indicated part, the famous "Coin Magazine Lock Arm," AKA part# A-102. It swings on a roller-cam and unlocks the carousel just before a payout; on the next pull, it can aggressively re-engage the carousel and-- in a worst-case-- backlash the coin magazine far enough in the clockwise direction that it delivers an extra coin into the payout cup. What I did about it? I simply shimmed the thing with a binder clip so it wouldn't swing back so far, such that it still locks back the carousel for the ensuing cycle to run properly, but doesn't push the cogs under the coin magazine around any further than that. I'm sure there's a better fix (there's gotta be) but that cheap remedy worked so well years ago that I never had another problem with it and promptly forgot all about it. A better approach may involve an adjustment to the "Carousel Detent Pawl Release Camplate" (see a previous illustration) but I haven't tried fiddling with that yet.
