SLOT DYNASTY wrote:OK Gentlemen, I got my callback from the person that I mentioned above, that I was sure would know all about
the Jennings "Golden Nugget" machines in question.
I will try and be as brief as possible, and will start with the machine pix in this thread, from the top.
Photo1: This late chrome Jennings, is as I thought it was. A TOTAL FAKE. Was also informed, that he was sure
it is one of the Vegas Butchers creations, as he was known to slap these together.
Photo2: Is definitely a Hans FAKE. The case and coin tray are not correct. He knew that Hans had been putting
these together for quite some time.
Photo3: This is a REAL Mills HalfTop "Golden Nugget". Everything is correct, and it is totally original. As you
can see, it does not look anything like the 99.9% of all the FAKESTERS on eBay, and elsewhere.
Photo4: This Jennings "Chief - Golden Nugget", is also the 'Real Deal'. It has the correct chrome wrap-around
coin tray. These models were on location in the Casino, and were on floor stands. So, the machine will
have a hole in the base panel, for the overflow to fill the large canister or bag in the base. All of these
models also had a hand-load jackpot, but the mech. had to be slid out to fill it. Unlike the key-operated
front-load on the Mills. I was also told, that some of these models had a dollar bill acceptor, attached to
the upper left side, next to the reel window, when on location. Now, when will one of those show up? It
must look very interesting. But I'll bet that the Casino removed those, before they left the premises.
But any of those machines will have an opening in the side panel, or at least extra bolt-holes.
So there you have it. Some real honest-to-goodness, good news for a change.![]()
Thank you Bill,
Knew you would have a definitive answer as usual!
So the answer to my question is that they did use Jennings slot machine in the Golden Nugget, the Jennings Chief model!
Probably not as many in count as the Mills Half-tops that were used as on Alan's site under antiques he does make mention to about 200 Mills Half-tops originally used.
Since there were not as many Jennings Chiefs used they are probably "Very Scarce", don't want to say "Rare", that word is over used, and being "Very Scarce" are probably all in the hands of avid collectors, while the Half-tops, being more in quantity were copied profusely in the market as you mentioned!
The production time of the Mills Half-tops and the Jennings Chief from the factories, in my opinion, match the usage of the slot machines in the casino also!
The production time of the Jennings Sun Chiefs would have been slightly later!
Kudos to you Bill and thanks for your input.
On our next phone chat I will ask you who your source is!
Take Care My Friend,
Ciao,
