Do these look original or not any other info appreciated
Re: Do these look original or not any other info appreciated
Postby aristocrat » Wed Jun 22, 2016 11:01 am
Is that x50 cent fancy coin entry an original mills production part
Or is it a revamped or a mills special customer order production
There seems to be very few on the market compared to the others
Or was it a later production therefore meaning there are fewer available
as less made due to late production stsrt?
Thx
aristocrat
Postby Richard13 » Wed Jun 22, 2016 12:44 pm
Sorry I do not know I just grabbed that photo off the net because it was clear and machine painted what I thought were correct colors.
Richard13
Postby SLOT DYNASTY » Wed Jun 22, 2016 3:21 pm
To all interested:
Here is a shot of the $ "Golden Falls" that I referred to above. I really don't think that this was Mills produced. They either hired an outside source,
to make a few for special order, or more likely it is an operator conversion. Regardless of whom it was, they sure put a lot of work into changing
the pattern for that upper casting. Plus, the changes to the mech., for the new coin acceptor, which is now located on the right. Also notice that
the cherries are mounted in the opposite order from all other denominations, because of the new coin-view window. And to top it all off, it has a
single cherry pay. You would have also thought, that with all the pattern work that was done, they would have filled the original escalator window
area. It would have looked much better. But then again, what did they care about looks back then?
