Getting a 1947 Mills Jewel Bell working again.
Re: Getting a 1947 Mills Jewel Bell working again.
Postby watlingboy » Thu Jun 12, 2014 8:43 am
The mechanism does not have to be in the case for the handle to come back up. Have you removed the handle and cleaned the old grease off the handle and hub in the case? This should be done on every machine which as been sitting for some years. If you did that and it still doesn't return, disconnect the pump linkage. The problem is either the handle has been switched and it is binding in the hub or the pump is not working.
Postby TheFatman » Thu Jun 12, 2014 11:23 am
If the handle does not return up on its own,( I was under the impression that it went up very fast), loosen the nut on the screw on the back of the pump, pull the handle down. While it remains down... back out the screw on the back of the pump slowly. You should see at some point, the handle should start returning up. This, I adjust while the mech is in because, the mech does aid a little in the return of the handle and you will get a better return that way instead of doing it without the mech. But yes, it is true, the handle should return to the top position without the mech being in the cabinet, usually when properly cleaned and lubed and a proper spring in place..
Dave F
