Stumped
Re: Stumped
Postby SLOT DYNASTY » Tue Sep 24, 2013 3:31 am
altort wrote:Bill,
Do you want numbers off of all makes and models of trade stimulators? Not sure were to find numbers on all the stimulators,
or if they all had numbers, and do you also want slot numbers?
Al
Al:
Regarding Trade Stimulators..................
Yes, I would like any numbers that fall my way. Only thing is, that not all mfrs. serial #'d their machines. Every so often, I will
find a number on a machine, that usually didn't have them. So maybe some mfrs. started to serial, and later didn't, or they
started to number later in the run. Who knows? There are some machines that were always numbered, via a paper sticker inside
the case, of which most have fallen off over the years, mainly because of the old glue drying out. Many of those machines, you
will see a brown spot where the paper was. Some of these examples are the Mills "Tickette", Rockola "Hold and Draw", Mills and
Jennings "Target Practice", and several others. Two other things to be aware of, is a machine that always has a serial in a certain
place, but has an additional number stamped elsewhere, usually a single or double digit on the top of the case. Those were put
there after production, by an operator, as his personal #, or the machine location #. I have run across a few machines over the
years with a same number. I have also seen a letter with the #, and even just a letter or two. Maybe those were the operators
initials? I had contact with a few old-time operators back in the 70's & 80's, but never thought to ask any of them about it. All I
was interested in hearing, was which machines they had on their routes.
The Mfr. that I have the most serials from, is Daval, and most all models will have the number stamped into the outside bottom
casting. Some models have a steel swivel plate on the bottom, so you have to turn the plate, so you can see the number. One
for-instance would be a "Reel Spot". Another place they put the serial on a few models, was on the backside outer edge of the
lower casting, just below the door. Examples of those, are the "Tally", the taller case model of the "Penny Pack", and others.
The later Daval wood case models will have the number stamped on the bottom, or on the back, above the door.
The Trade Stimulator Mfrs. that did serial their machines are: Daval, Mills, Jennings, Caille, Superior, A.J.Stevens, Rockola,
Bally, Fey, Fields, Keeney, Exhibit Supply. Groetchen also had a numbering system of sorts, but they were not stamped into
the castings. They were painted with a small brush, inside the case. Usually on the front, which you can only see with the
mechanism out, like the "Mercury", "Liberty", "Sparks", etc. The "Ginger" will have the number on the inside top. Some of the
models will also have the same number painted on the metal plate of the mechanism, below the reels, or on a side panel. If
any of these models has been fully restored, and the inside of the case bead-blasted, then the number will not be present
any longer. Also, if the number on the case is different from the number on the mech., would usually indicate that someone
switched the mech. at one time. Another thing that I also log, and don't always get, unless I see the machine in person, or on
eBay, will be from a machine like the Daval "American Eagle", is which reel strips it has, (as they had 5 or 6 different styles),
the coinage, (1c, 5c, or non-coin), if it has the gumball feature, and the orig. color scheme. If it is a non-orig. repaint, I will
just list it as a 'repaint'. There are also many other small features that they put on some models, but not on every one.
Another Daval feature I log, is if the "Marvel" has the large or small nameplate. I have learned the most about Daval, regarding
how long they made certain models, casting changes, different color schemes, and special short-lived features. It would take
more than 2 or 3 pages, to list all of the differences, just in the Daval line. Dick and I were the only ones interested in serial
numbers, and machine variations. Most collectors didn't give-a-hoot about all this nonsense. The only ones that cared at all,
were the ones that gave us a Slot serial, so we could date their machine. What I use to view as a waste-of-time, regarding
the trade stimulator serials & info., I now find rather interesting. But that's just me! :roll:
One other thing that I hate to do, is bug people for serials that they may have already sent, but I have no way of knowing
unless I get the number again, as they are filed by number, not by who sent it to me. It's only after I pull the card, that I see
who sent it, and when. Sometimes I will get the number from a new owner.
To answer your other question.............Even though I haven't been asking for any lately, Yes I will still take any Slot serials
as well, and add them to our past listings. I would also like to know how many serials were added to the last listing that Dick
passed along before his departure. As I am sure that I never got a copy. I especially would like the serials from any Victorian
Uprights. They tell an interesting story as well, from all the changes in the wood gingerbread.
Re: serial number collection and management
Postby mtstanley » Tue Sep 24, 2013 5:53 am
I have an ad agency and we do many web related projects. To put develop a web site that would be available for everyone isn't that difficult. What I'd do is build a relational database site, create a landing (page) site for entering new submissions and you'd have everything in one spot. The time consuming effort would be linking the information to fields which isn't difficult.
Then you would have a site someone could search: for manufacturer, model, serial number, quantity, colors, quality, etc. anything you'd want. The one issue to focus on would be having control; someone that could monitor the site to make sure new data was accurate.
If someone gets a list, I'd like to see it. What form it is in, etc. If it is typed, it can be scanned and made into digital information, if it is digital text, it can be separated into fields, if someone had already put it in a database format, creating a website should be easy...stan reed; sreed@rsandk.com
mtstanley
Postby Dave » Tue Sep 24, 2013 9:01 am
mtstanley wrote:I have an ad agency and we do many web related projects. To put develop a web site that would be available for everyone isn't that difficult. What I'd do is build a relational database site, create a landing (page) site for entering new submissions and you'd have everything in one spot. The time consuming effort would be linking the information to fields which isn't difficult.
I have been contemplating doing this for a couple of years. I figured I would either tie it in to the forum, or the price guide, or my own website.
I just don't know how many people would use it. Also, many people don't have a clue where the serial number is on their machine and they would put in things like patent number or model number or any number that they can find on the casting. In addition, some companies put letters in front of the serial numbers (e.g., ROL on Rol-A-Tops, FK on Pace machines). That makes the problem a little more difficult. When you add the fact that operators sometimes stamped their own numbers on machines it adds to the problem. Finally, the folks who are making the fakes usually don't put serials on them but SOME do. I think the guy in Canada who made all the fake cast iron machines put serial numbers on them.
A friend of mine in Denver used to sell a serial number list. He advertised it in all the magazines. I asked him how many people bought it and he indicate very few. I asked him if he would give me the list so I could start this project. He really didn't want to.
Re: Stumped
Postby Midcoast Vintage » Tue Sep 24, 2013 9:10 am
what cast iron machines were faked in canada?
Re: Stumped
Postby watlingboy » Tue Sep 24, 2013 9:11 am
The list was typed on 8 1/2 X 11 paper and xeroxed. There were maybe 25 or 35 pages , as I recall.
Re: Stumped
Postby marsonion » Tue Sep 24, 2013 9:17 am
A friend of mine was trying to set up something like this a while back, but I don't think it got very far:
http://www.slotmachineclub.com/Serial%20Numbers.htm
I have a few pages copied by another very generous and helpful friend from a list of Bueschel's compiled serial numbers (which appear to have been very well organized, BTW) for Caille slots. These appear to have been self-published by "Ed and Richard Zimmerman" sometime in the '90s.
Re: Stumped
Postby Dave » Tue Sep 24, 2013 9:25 am
Midcoast Vintage wrote:?????
Mills Liberty Bell. Once that was done the value plummeted on the real ones.
Re: Stumped
Postby watlingboy » Tue Sep 24, 2013 10:22 am
There were approximately 25 made. Most were Mills Operator bells but some were Mills Liberty bells. Most if not all had the correct pin fingered mech in them. The plating on them is very bright and shiny.
Re: Stumped
Postby Midcoast Vintage » Tue Sep 24, 2013 1:08 pm
good to know.
thank you.
Re: Stumped
Postby altort » Tue Sep 24, 2013 9:21 pm
Ok Bill
This might take a wile since I am re doing my game room over and I put most of my machines in storage. I figure might as well start with my Jennings, hope I got them right,
5 cent Jennings Baseball 9058 are the only four numbers stamped right side of the goose neck,
early 5 cent Jennings goose neck I believe to be a Rockola revamp 13837 numbers found on the sub base between upper and lower doors,
50 cent peacock goose neck 111687 stamped right side of goose neck,
Jennings Triplex XXX2644 were found on the insides of the lower casting, upper casting and bonnet,
I did not find numbers stamped on my Little Duke will need to look at it further.
If any of these numbers dont match up with what they should be let me know witch slot and and I will look again.
PreviousNext
