Penny pack reels
Penny pack reels
Postby mauzio » Wed Mar 31, 2010 1:29 pm
Hi. I just bought a penny pack, but the reels are spinning very shortly. Is this normal for this type or machine. Or is there a way i can adjust this?
Thanx.
Maurice.
mauzio
Postby cpdretired » Wed Mar 31, 2010 2:30 pm
Try adjusting the air pump by turning the screw counter clockwise. You can also spray a little WD40 onto the shaft that the reels are on. Be careful not to contaminate the reel strips with the WD40. Use as little as possible.
Ron
cpdretired
Postby drwstr123 » Thu Apr 01, 2010 2:24 am
How mechanically inclined are you?
The piston works like a bicycle pump. There's a leather diaphragm that acts as a seal. They dry out and leak. (lose air)
If the seal is only dry, I use Vaseline to moisten it. If it's deteriorated, I cut a replacement from similar leather, lubricate with Vaseline, and replace.
Adjust as previously suggested.
drwstr123
Postby mauzio » Thu Apr 01, 2010 9:59 am
Oke, thank you! I´m going to try!
mauzio
