Repair Question on 1937 Rolatop
Postby multiham » Sun Jul 03, 2011 8:14 am
Looking for some help! Purchased a 1937 Rolatop $.10 from Bob Levy about 18 months ago. Has worked perfectly until today. Now, when I put in a dime (any dime), it comes right out the coin return slot on the right of the machine.
I know very little mechanically about these machines as I always turned to Bob whenever I had the slightest problem. Hoping someone can give me some good advice on what to look for to correct the problem. I took the machine out of the case and could not see anything obviously wrong. Tried putting dime in with machine out of case. Dime moves so fast that I can not tell what is going wrong!
Appreciate any help!
Steve
multiham
roll a top jam
Postby radiorich123 » Sun Jul 03, 2011 10:32 am
Look for a dime that is jamed in the coin path. If you can not fix it I AM located in North NEW JERSEY and can fix it for you. I have the same machine.
Rich 973-694-6374
Postby multiham » Sun Jul 03, 2011 1:48 pm
Thank you!!!
I had looked before, but there were actually 2 dimes (one on top of the other). I was easily able to remove and everything works.
Really appreciate the help and glad to know that there is someone not that far away if I need to get repairs.
Steve
multiham
