Can someone help date 2 mills machines
Postby kepmr » Tue Sep 06, 2011 6:58 pm
Just bought 2 machines would like to date them.
Golden falls 529843
Skyscraper 355407
kepmr
Dating Golden Falls and Skyscraper
Postby PeppiB » Wed Oct 12, 2011 5:38 pm
According to the serial number listings compiled some years ago by Dick Bueschel and Ed Zimmermann,
1) The nearest Golden Falls is #529,690 with production in 1945-46 -- as you may be aware, this was the last model before the hightop was introduced.
2) The nearest serial # to the Skyscraper is a Blue Front with serial # 355,089 with a listed production date of 8/20/34 -- so I would assume that your production date would be in Sept. or Oct. of 1934.
PeppiB
Postby kepmr » Thu Oct 13, 2011 1:19 pm
Thanks for your help
kepmr
Re: Can someone help date 2 mills machines
Postby fast_in_muskoka » Fri Aug 23, 2013 2:02 am
Out of curiosity, where would a Skyscraper serial # A390126 fit into the timeline of Mills slot production ?
My Skyscraper seems to be completely original ( not restored ), totally complete and functions and pays out 100% correctly.
Jackpot counter registers 157.
Front / manual load Jackpot and has both removable casting doors on the front of the housing.
Does anyone have an idea of what the purpose of the casting openings were ?
regards,
Steve
fast_in_muskoka
Postby andydotp » Fri Aug 23, 2013 2:20 am
Wow, Yet another variant!
I don't recall seeing a hand load Skyscraper before. The panel just right of the jp window is for inspecting the jp mechanism, as for the little square one above (I've asked the same question here too), no idea other than peeking inside at the gooseneck.
Nice machine BTW.
andydotp
andydotp
Postby fast_in_muskoka » Fri Aug 23, 2013 7:34 am
My opinion is that this Skyscraper looks way better than any painted versions I have ever seen.
I assume that the plating is original, and hopefully someone can jump in with any comments on that thought.
Thanks for the compliment on my slot ( I play it daily as it sits in the kitchen beside my fridge ).
These "access panels" secure with hardware from the inside, so to peek @ mechanisms, you would have to slide the guts out, remove the "panels", and reinsert the internals.
andydotp wrote:Wow, Yet another variant!
Nice machine BTW.
andydotp
fast_in_muskoka
