Caille superior 25 cent id
Postby sam2002 » Wed Feb 01, 2012 6:45 pm
Hello
Great forum you all have here . I have recently accquired a Caille superior quarter machine , I ran across a topic somewhere in here that mentioned lots of the machines had been shipped to France as penny machines (French pennies were apparantly about the same size as our quarter ) Any whoo what I'm wondering is how do I interpert the various numbers that are stamped on this macine ? 30433 is stamped on the upper outside case on the pull side , then there is M1586 stamped on the top of the case on the pull side , 28946 is stamped on the mech .
I would like to know if this machine is original . Also if were export or domestic . It's a neat machine and I plan on enjoying it for years to come .
Thank you in advance for any help
Sam
Re: Caille superior 25 cent id
Postby marsonion » Wed Feb 01, 2012 10:47 pm
Pictures might help :)
Generally speaking, there are serial numbers and there are part numbers. I'm guessing (not sure of course) that you have a somewhat earlier production mech (#28946) in a somewhat later cabinet (#30433) which I'm told isn't that unusual since a gambling venue typically had multiple machines and would swap out mechs here and there for service and maintenance.
Interchangable parts had catalogue numbers for everything down to the smallest castings, and each part was typically stamped or embossed with a reference code. But "M1586"-- no idea. Doesn't even sound like a Caille part number to me, but I've been wrong before...
sam2002 wrote:Hello
Sam
Postby marsonion » Thu Feb 02, 2012 11:23 am
sam2002 wrote: I ran across a topic somewhere in here that mentioned lots of the machines had been shipped to France as penny machines (French pennies were apparantly about the same size as our quarter )
I'd like to know more about the French Connection too. Though all production was at their massive Detroit plant (which still exists and was renovated recently), the Caille Bros. Co. maintained a sales office in Paris. Not so sure about some of the other claims:
http://fadeddetroit.blogspot.com/2010/0 ... lding.html
I'm posting pictures of the locations of the serial number on my GP. Also an image of an item the Caille parts catalogue lists as no. 689, "Mechanism Coin Top Cover (Specify 5c, 10c, 25c)." It has a big "25" stamped on it which I'm certain indicates the denomination of US currency, not French. Above that is the number "45689."
Caille Superior mechanical parts are listed in one, two, and three-digit mostly consecutive codes, which then jump to five-digits starting with 40XXX. There are no four-digit part numbers listed in the catalogue! Go figure...
Postby sam2002 » Fri Feb 03, 2012 4:21 pm
Appreciate your help . This Caille has that same part with the 25 stamped on it and my serial numbers are in the same place as your arrows , with the exception of
1.) Another number has been stamped on top of the case near where you have your arrow except it is on the top of the cast it is stamped M1586 .
I wonder if that may have been put there for tracking by a casino ?
2.) on the inside of the case where you have the arrow this machine has a 3 3/4 x 6 3/8 piece of sheet metal screwed to the wood . Maybe the number is under that ?
I am not aware of the catalogue you are refering to with part numbers .
Are copies of this catalogue available ? If so where might I find one ?
Thanks again for your help
If I find my camera I'll post some pics
Sam
Postby marsonion » Fri Feb 03, 2012 5:10 pm
sam2002 wrote:I am not aware of the catalogue you are refering to with part numbers .
A reprint of operator's manual catalogue of parts appears in this guide:
http://www.crowriver.com/books/bk10803.htm
Good luck--
Postby sam2002 » Sun Feb 05, 2012 2:50 pm
pics added
Users browsing this forum: No registered users and 22 guests
