Extrabelle Aitkens Front Dime 10
Postby sam2002 » Fri Feb 03, 2012 4:44 pm
Hello
Since I had such good luck with the Cailee ID questions I'm going for another .
I am fairly new to coin op collecting and the forum .
I have recently accquired a Mills Aitkens front that is supposed to be an original .
What or where can I look for information on this machine to help identify it as either repop or original ?
Are there clues in the mechanism ? How about the case ? any distinguishing characteristics in the castings ? Are there certain serial #'s to look for ? etc .
Thanks again in advance for any help you can be .
Sam
Postby nvmos2 » Sun Feb 05, 2012 9:38 am
I was hoping this post would get some response from the experts; I'm not one of them and don't know any details on this specific model.
All I can suggest is experience; the best way to spot a fake is look at it closely. Of course this requires that you closely examine as many original machines as possible to begin with, so you know what they are supposed to look like. Once you've compared a Sega mechanism to a Mills mech, you'll have no trouble spotting a Sega mech that has been inserted into a Mills case. To get an idea what a repo case looks like, have a look at ebay auction 320842859886.
Book knowledge is also very helpful; The Coin Slot Guides and reprints of original factory material can be helpful to know what features a specific model/year group had and how the machines developed over the years. That can help spot a later model mech that has been insert into an earlier model machine. Also, books often have good tips; for example, Slot Machine Buyer's Handbook by Saul/Mead has a whole chapter entitled "Traps for the Unwary."
All I can say is, if it looks too good to be original, it's a suspect machine.
Postby WS65711 » Sun Feb 05, 2012 12:05 pm
Unfortunately, I'm no expert either. But I do know that pictures always help. If you could post some, they would certainly be of help to anyone who's trying to help you. :)
WS65711
Postby sam2002 » Sun Feb 05, 2012 2:06 pm
OK and thank you for your help
I will look for the book you describe .
Postby sam2002 » Sun Feb 05, 2012 2:21 pm
pics added
Postby sam2002 » Sun Feb 05, 2012 2:33 pm
pic
The topper shown here is cast iron
Postby nvmos2 » Fri Feb 10, 2012 7:44 pm
Nice machine; for comparison purposes, you probably saw the one on ebay, number 270907110773, it has the patina of an original machine (with a chain drive escalator!). If you look closely, you might spot some difference in the scroll work.
Slots 2 has a write-up on it; not properly called the Aitkens Front; it's the Extrabell, not made by Mills; it was a revamp kit that included the cabinet only. So, if you have Mills decals on the sides, that would be incorrect. I don't know what colors it was offered in, I've only seen the light blue, like the one on ebay. Slots 2 says it was chartreuse and gold!
It was designed for any Mills Silent mechanism and escalator.
Unfortunately, I believe they have been reproduced. I would suspect any cabinet that is not light oak, without dents/chips/cracks, without hammer tone paint in a known color.
I don't think Extrabell supplied the back door; that should be a Mills door. That does not look like the standard Mills instruction sheet on your door; does it give any clue in the fine print who made it?.
It would be interesting to know if Extrabell put serial numbers on them. I don't know if there is a distinguishing feature on the repos.
