Mills Vest Pocket help needed
Postby slotsdirect.com » Tue May 01, 2012 3:29 pm
I have a Vest Pocket with the reel strips totally removed. I ordered new strips but need advice on how to figure out how to apply the strips in the right sequence and locations....any help greatly appreciated
slotsdirect.com
Re: Mills Vest Pocket help needed
Postby MikeB » Tue May 01, 2012 5:31 pm
Cycle the machine, and then hold the clock fan blade mid cycle. Spin the reels until you think you have it centered on where ALL 3 jackpot symbols (can't remember on Vest Pocket, but might be 3 Cherries) centered, and let go of the fan blade. Let the machine cycle all the way, to make sure it pays off the full 20 coin payoff.
You now know that all the jackpot symbols should be located across the middle line, so place them that way. Each strip should also have a number on the back corresponding as to which is #1, #2, and number #3.
MikeB
Postby slotsdirect.com » Fri May 04, 2012 1:31 pm
This picture is from the top with the coin slider to the left
OK Great I got the new reel strips in place....thanks for the help. Now a new qquestion. I have a spring on the inside above the coin slider that I cannot figure out what it does and what the right end of the spring should be clipped onto. I have a photo and I have studied the manual and cannot find the answeer. I wish I had another Vest Pocket to look at. Please if anyone can help me just look at the picture and let me know. Thanks very much !
http://www.slotsdirect.com/spring46-3question.jpg
slotsdirect.com
Postby FOREST » Fri May 04, 2012 7:53 pm
It sits on top of the large flat head screw shown in your pic
FOREST
Postby slotsdirect.com » Fri May 04, 2012 8:06 pm
Thanks very much...I really appreciate your help !! I put it there and it works !!!
slotsdirect.com
Postby 5 cent player » Sat May 05, 2012 8:42 am
as stated,,,,,
5 cent player
Postby 5 cent player » Sat May 05, 2012 8:46 am
Also, that flat head screw should have a shoulder or step under the screw head to allow the slide to move under it
5 cent player
Postby slotsdirect.com » Sat May 05, 2012 11:18 am
OK thanks. Your photo is very helpful!
slotsdirect.com
