Watling Blue Seal
Watling Blue Seal
Postby oldslotman » Sun Apr 28, 2013 7:33 am
5 cent Watling Blue seal. What are they worth??
Re: Watling Blue Seal
Postby terick2104 » Sun Apr 28, 2013 8:02 am
I just sold a nice original one on April 4th for $1100.00 Ebay # 160997556831
terick2104
Postby oldslotman » Tue Apr 30, 2013 2:49 pm
The one that I'm looking at is 1928 or 1929 Blue seal with a single jackpot. Are all the Blue seals 10 stop, and what type of rear door did they have? This one has a flat back door which is not very heavy. I believe it is a replacement door and lock.
Postby terick2104 » Tue Apr 30, 2013 7:34 pm
The original door is a plain flat door that is fairly heavy. As far as I know they were all 10 stop machines.
terick2104
Postby oldslotman » Fri Oct 04, 2013 11:43 am
Are these machines noisey when you play them? Is there a clicking sound that comes from the reel stops before the reel stop? I believe it is a 10 stop machine.
Postby watlingboy » Sat Oct 05, 2013 3:33 pm
All Watling mechs make a tick, tick, tick sound as the reels are stoping. That's because they have fingers which stop the pay discs as opposed to reel stop arms which go into a star wheel. So yes, it is normal. It is often described as a tinny sound. Most machines do not have the reels adjusted properly which will lessen this noise. All slot instruction sheets which came with the machine originally, whether it is an upright or a three reel machine, said the same thing, the wheel or reels should come to almost to a stop before the reel arms or fingers are engauged. To have the reels spinning like crazy and then have the stop arms or fingers release only wears out the machine. So be sure the reel brakes are adjusted properly.
Postby SLOT DYNASTY » Sat Oct 05, 2013 8:18 pm
I always described the Watling sound, as a 'cling-clang-clack'. :D
As far as reel brakes go, most people now, would ask you, "what's a reel brake"?
Have you ever noticed that many of the original machines shown on ebay, with mechanism shots, are void of brakes.
Not to mention all the REPRO's, that never had them installed. I think many do not know the usefulness they serve.
Every slot that I have ever restored, be it mine, or a customer, has always had them installed if they were missing.
Postby oldslotman » Sat Oct 05, 2013 9:01 pm
Thanks for info guys. I thought it was normal for a Watling but I just wanted to hear it from others who know for sure. Thanks again.
Users browsing this forum: Google [Bot] and 5 guests
