Questions about my Rol A Top
Postby kingsley » Fri Oct 04, 2013 3:55 pm
I posted on the fantastic finds a few weeks ago about getting my hands on a original Rol A Top. I posted a pic. Today I took it to a locksmith and got into it. The seriel number on the outside can't be read but on the inside it is very light but appears to be 4586H. If the last diget is not a letter then it may be a 4. Under the number ithe second line is a 9 and under that on the third line appears to be $135. Any idea as to the age?
Also I did not see any real jams but there are no coins in the round dial and it appears that a bar goes through a hole under the wheel and if it does not hjit against a coin it will not let the handle depress. How do I get coins into the small partitions within the circle? Sorry for my non-slot machine jargon. Any areas to check.
The inside looks good and I am hoping I can get it operational without too much trouble.
kingsley
Re: Questions about my Rol A Top
Postby watlingboy » Fri Oct 04, 2013 8:36 pm
That is not a serial number Watling used. The last digit is probably a number 4, they never used letters and the first number that you think is a 4 is a 9. Look at the end of the wood blocks under the sub base, the serial is usually found there also. It could be on the end of the right hand block but is probably on the end of the block on the left. Your machine was made in the late 40's.
Need more information to help you with the escalator problem. Is it on free play? That pin is supposed to go through that hole at the bottom of the escalator if no coin is played. By holding back the arm the pin is connected to and pulling the handle, you can play the machine. If no coin is going down into to the area for the pin to hit it, where is the coin going?
Postby kingsley » Sat Oct 05, 2013 7:56 am
Thanks. You are correct, it is a 9. I see no other numbers around the bottom two blocks.
I put the works back in the machine and pulled back the arm the pin is connected to and pulled the handle. It actuated and but it it was forced some and made the same noise that it makes when the handle is pullled without a coin in it. The noise sounds like it is more towards the middle or bottom of the works. I only pulled it a few times because it not right and I don't want to cause any more harm to the machine.
I also noticed when the handle is pulled the wheel does not rotate. It seems to stay in the same place so I am going to look for a jam where the coins feed into the wheel. I have done so once and found two coins side by side right next to where they enter the the wheel but are hard to back up enough to remove.
Just to the right of that brass 5 cent disk in the center of the circle is a small lever that pivots on a small horizontal shaft and the top of it serves to keep coins coming down the shoot from falling out. There is a very small tip that has what appears to be the remains of a very small spring. There is no spring. If there is one what does it connect to? If this is important I have small springs in my shop and can replace it.
Any ideas?
kingsley
Postby kingsley » Sat Oct 05, 2013 8:40 am
Here is a pic of the wheel area I was discussing.
kingsley
Postby nvmos2 » Sat Oct 05, 2013 8:50 am
kingsley;
I am familiar with Watlings (probably not nearly as much as as others here), but I haven't got a clue what you are trying to describe.
It sounds like you have more than one problem; a problem up top in the escalator and another down in the mechanism.
"What we have here is failure to comuncate."......Cool Hand Luke.
As stated by Watlingboy; "need more information to help you."
Before you go any further, I recommend you go to You Tube and search on "Unjam Rol-A-Top"
You will find 2 excellent videos (part 1 and part 2) that will help you understand how your machine is supposed to work.
Watch them a couple times; that may be all the help you need.
If not, it will help with your terminology and maybe you and Watlingboy can get on the same page to get your machine working.
Postby kingsley » Sat Oct 05, 2013 11:52 am
I watched the videos and they were some help. I managed to get the jam fixed, the wheel free and full of nickles and now the machine works. The second problem is when you pull the handle down just as it activates it makes this noise and is definately binding a bit on something. It releases and everything works but it is not as smooth as it should be, there is a slight hitch in the handle and it makes this binding noise like something being forced. I had someone feed nickles and slowly pull the lever in the front and I looked in the open back and the bind appears to be on the left side about half way up. it is hard to pinpoint the exact location.
I was told by the previous owner that when it was jammed someone pulled the lever and got the machine to work without inserting a coin and that may be the beginning of this problem.
Anyone know of any reputable repairmen in the Houston area?
kingsley
Postby SLOT DYNASTY » Sat Oct 05, 2013 12:22 pm
Your binding problem may be at the front part of the mechanism, that you can't see by just looking in the back during play.
The best bet, is to take the mechanism out of the case, and play it on the bench, that way you can see all sides as it is operating,
and possibly see what is rubbing or binding. It may be that a previous owner bent something slightly, while prying with a screwdriver,
or whatever, and made a situation worse than it was. Many past machine operators may have thought they were a mechanic as well,
but weren't. At least you got one of your problems solved with the coin escalator, and that's a plus. Congratulations! I trust you will
find this other problem just as easily, and be on your way to many hours of enjoyment with your new machine.
Postby TheFatman » Sat Oct 05, 2013 12:56 pm
SLOT DYNASTY wrote:Your binding problem may be at the front part of the mechanism, that you can't see by just looking in the back during play.
Ditto ... operating the mech out of the cabinet lets you watch all angles of the mech and slowly advance the mech to see what might be binding. You can still insert a coin and activate the mech or hold the coin register rod back. I feel using a coin in the mech will give you the best results because there might be a coin in the mech issue but I think i would be more of an issue with the operating linkage.
Good luck and post pics when you solve the problem.
Dave .... AKA the Fatman... a few months ago
Postby nvmos2 » Sat Oct 05, 2013 1:34 pm
kingsley;
Glad the videos helped with escalator problem.
As for second problem;
"slight hitch in the handle and it makes this binding noise........on the left side about half way up."
That's where the handle and the mechanism interface.
As stated above, try the mechanism on the workbench out of the case.
If it runs smoothly, check the handle operation with no mechanism in the case.
If it pulls and returns with no binding, sounds like an interface problem, which should be really easy to fix (easy for me to say).
maybe the mechanism isn't seated properly or something on the handle assembly or on the mechanism is sticking out too far and causing the binding when handle is pulled.
I hope we will hear very soon that you zeroed in on the problem.
Postby kingsley » Sat Oct 05, 2013 2:27 pm
"sounds like an interface problem, which should be really easy to fix (easy for me to say).
maybe the mechanism isn't seated properly or something on the handle assembly or on the mechanism is sticking out too far and causing the binding when handle is pulled."
Sounds reasonable to me. There is the same binding and noise in or out of the case. The handle on the case is free and works well. I just ran a dozen nickels through it again whiile it was out of the case and pulled the screwdriver down as slow as I could and when it reaches the bottom and activates that is when it makes the noise. It appears it might be down on the lower left side towards the back of the case. There is a 1/4 " square bar about 1 1/2 " long that is at the lower back left side (facing the back). The noise appears to be coming from right in front of it but there is a bunch of stuff happening there at once. That is about as close as I can figure. I oiled everything in that area but no change. It is interesting how many different systems are activated at once and I am amazed you guys can figure it out, My brain is tired and I will have a look again tomorrow.
I have made progress today. I have gone from having a non funtioning rol a top to one that works but scares babies.
thanks for all your advice.
kingsley
Users browsing this forum: Google [Bot] and 5 guests
