Help on repairing Columbia payout
Postby flipper77 » Mon Oct 14, 2013 10:05 am
Recently picked up standard Columbia. Have gotten it all working except payouts are one coin short. 3 and 5 for cherries are actually 2 and 4, 9 payout instead of 10 for oranges - one coin short across full payout range. This is a dime denomination but carrousel function should not care (though wish I could convert over to nickel or especially quarter - any one with parts for a Columbia?). Before I start tearing into carrousel and the advance and brake levers, thought I would ask if anyone has any experience on fixing Columbia payouts? Any advice or guidance much appreciated!
Flip
flipper77
Re: Help on repairing Columbia payout
Postby Midcoast Vintage » Mon Oct 14, 2013 10:19 am
THIS BOOK ON EBAY MAY, OR MAY NOT ANSWER YOUR QUESTION.
THERE IS NOT MUCH AVAILABLE INFO FOR COLUMBIA MACHINES.
http://www.ebay.com/itm/INSTRUCTIONS-HO ... 3a8618c953
Postby flipper77 » Mon Oct 14, 2013 10:50 am
Thanks and yes I saw that. i know Gordy Nichol. If no one has any info, will probably buy the booklet in hopes of a hint. Thanks.
Flip
flipper77
Postby marsonion » Mon Oct 14, 2013 11:52 am
To increase the payout by one coin, loosen the screw holding the "Semi-Circular Payout Arm Guideplate" and slide it counterclockwise a little, then retighten it down. Play with that adjustment a few times and see how it works.
Unfortunately, if your machine is bent like mine is, you might find sectors of the carousel delivering four and six coins, etc. after other portions have been "cured" of the short payouts.
The denomination coversion parts occasionally show up on eBay for a hundred bucks or so. Mine arrived in a little burlap bag, and included the larger and smaller diameter coin entries, a couple little hook-like parts to funnel the coins to the detector and replacement denomination tags. Conversion takes only a couple of minutes.
Postby flipper77 » Mon Oct 14, 2013 12:31 pm
Thanks much. Will give that a try. Also found that my rod that the tube slides back and forth on was dirty. When I cleaned it off and increased the spring tension a little, I got one five pay on cherries and lemon. So may be a combination of issues. But your tip will come in handy. Great to have this blog and all of the knowledge!
Flip
flipper77
